What Would You Do To Your R35 With 25 Grand?
Thata a bit boring... lol
Nah, I bought the 35 to thrash it, not to baby it around and show it off to friends from my garage
Might be a little full on? Maybe the p600?
sheil be right!
in all seriousness, I would like to get 10.xx down the 1/4.
Whats it take for the gtr to run 10's?
keep in mind its still going to be a street car.. will be used on track more then drag, but still want to own a 10 sec car before i die.
I can answer this!!!!! An HKS GT 570 kit, and a cobb custom tune, and the magic of Jim Souvas at CRD!!!!
I'd sell it and buy a ZR1 :banana:
Very nice birds...but that actually brings to mind another question. What would you do for $400,000 asking price of a ZR-1??.....I'd get the red GT-R and with the $230,000 change (!).. buy the magnificent new Infiniti M56 sedan (when it finally comes out)..that's a 5.6 litre V8 with around 300kW
...and $100,000 deposit on a beach house in Sorrento! :domokun:
$25k....hmm....
I would get the Upper control arm upgrade to allow extra camber, I would then get the stage one flash from Cobb (Or equivalent), the rest of the money would go in the bank for when something breaks and Nissan tell me where I can shove my requested warranty repairs.
The midpipe is a must also... but I have that so I can put more money in the bank.
  • 8 months later...
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
