Hey everyone,
so some of you might have read my thread about Tyre Power stripping my front wheel studs, i went out and bought new studs and am now currently trying to replace them, as per claims it should be easy lol.
I have removed the brake caliper and the rotor, so i have just the hub. I can see there is nothing holding the studs in place, so i screwed a nut onto the end and hammered away. Nothing... Studs wont budge at all. I have a feeling the studs are rusted onto the hub. I sprayed huge amounts of WD40 on the stud and the hole, but nothing works. Stud wont budge. Hitting the stud with a hammer has damaged it beyond use, so now i cant even put the wheel back on to take it to a mechanic.
Does anyone have an idea!?
https://www.sau.com.au/forums/topic/286021-urgent-help-needed/
Hey everyone,
Did you screw two nuts onto it, then tighten them together, and then use the one closest to the hub to try and unwind the stud ?
Tried both of those lol, neither of them worked. Ended up using a mallet so big, i actually think it may have been a warhammer. Gave it a couple of love taps, the studs twisted and bent and actually became became much shorter, and eventually came free. Replaced the studs and everything is all good now.
Cheers for your suggestions guys, sorry this thread kinda polluted the forum
So to chage the wheel studs, you obviously have to remove the brake caliper and disc....what exactly did you do to get the studs out? I need to replace two on my front right wheel this weekend....
Well as long as yours are in better condition than mine, it should be the simplest thing you ever do to your car. Problem was my studs were rusted onto the hub...
Anyway, its as simple as removing your caliper and rotor, getting a hammer (in my case an extremely large one), and hammering out the stud. If yours are rusted on like mine were, then i found that a fair bit of WD40, plus a hell of a lot more brute force was required. I also had to bash the stud in a few different directions, like underneath, on top, etc. just to loosen it up a bit.
But as i said, if yours are in better condition than mine, it is literally the easiest thing to do. Good luck man
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
