Hey guys up for sale is my r34 that has had no expense spared. It had a motor change (rb26) about 25k kms ago and is holding up perfectly, the car is making 291rwkw atm on safe tune (mines ecu) and will be putting out close to 350 with the new computer (power fc jetro). This car has been fully built by race pace and has been built to last.
MOTOR RB26
New forged pistons (race pace)
new forged rods (eagle)
new r33 gtr crank
new head
new high pressure/volume oil pump
new water pump
new race pace modified adjustable cam gears
new garret twin GT-SS turbos with upgraded actuators
new tomei gtr fuel pump
new modified sump
gtr intercooler
gtr injectors
apexi pod filters
new extreme cushion button clutch
3" high flow cat
3" exhaust system, car is very quiet
New front and rear r33gtr brembo brakes and new 324mm disks (front are slotted) (rear are drilled)
REAR END
Hks coil over hyper D, adjustable dampen
New lsd
Adjustable toe arms
Adjustable traction rods
Adjustable rear camber arms
Machined sub frame bushes c type
INTERIOR
Retrimed "too black" with red stitching
Drift gear knob
Blitz boost gauge
Sony dvd player "touch screen"
Turbo timer
Fire extinguisher
th_l_2f1774799c91a227e418741b19249b-1.jpg th_l_85d0adb7cf6cf25fb914d6f5f3fce8e6.jpg th_l_9b747088365852dbf805a7c34ab70793.jpg
if needed i can supply many more photos by either mms or email, i have most receipts and dyno sheets if needed. car has just been serviced and is in overall A++++++ condition
please no ridiculous offers and keep the stupid comments to yourself
car is located in murrumbeena, the custom plates may be included in the sale depending on the negotiated price
0433049322
https://www.sau.com.au/forums/topic/286029-vic-r34-rb26dett-eoi/
EOI pepe... make an offer, if its worth my while to sell the car i will other wise ill keep it as Ive spent way too much $$$ on it
Edited by s14_boosted
  • 3 weeks later...
  • 3 weeks later...
  • 5 weeks later...
i went and had a look at it today... i had to go home and change my undies, ill be picking it up nxt week sometime as theres a few parts to still put back on nd stuff,
offers over $30k
30k aint much as its a fully built r34 wit a top notch showroom paint job.
  • 1 month later...
forgot to add
*new s/steel upgraded front pipes
*new race pace made high flow muffler
*new high flow radiator + hoses
*aircons just been re gassed (icy cold) :ermm:
*the side skirts broke when the car was getting painted so the 1s on there now are brand new (bomex)
*new rear windscreen they cost big $$$ with fresh tint as old 1 had slight wiper wear
*fresh tread on all 4 rims + rw tread on other set of rims included in the sale
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
