I replaced the whole exhaust and intake, (yes even the intake piping from the throttle body) have a pod + heat shield. Got Tein springs and wider rims. I also had to replace the coil packs so i have brand new coils..
Only thing i haven't done is a tune, is there much a tune will do with such basic mods??
Btw its an R34 so it should adjust a few minor things by itself i think..
I'd be keen to do something else as long as it doesnt cost more than $2k (unless it gives an impressive increase to performance then i would look at spending more)
hey mate, im in NZ also, ive done all the same mods and after getting some advice from a couple of people on here i reckon the next best upgrade is gonna be new cams, especailly if you got a 2k budget!, but from what ive read our r34's will also need gtr solid lifters or soemthing like that, plus labour, so now cams is prolly tipping over 2k :D but they are supose to be good for like 30 kw with a good tune??
right now im just focusing on cleaning up the engine bay and trying to make the car lighter anyway possible with future upgrades
Edited by AYW550
well the ecus are capable of learning small mods like intake/exhaust by itself and adjusting...even if you reset the ecu so it learns how u drive i hear people saying that the car drives slightly better.
not to sure how much increase a emanage blue + tune will get you i still want to find out myself.
after all that not too sure what direction to go in mods..theres a topic all the top of the n/a section which tells you all mods you can do..
heres a good read for you
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
A guy was selling his R34 GT-R cams a while back and he said that they might be able to fit the rb25 (de and de-t). I'm not sure if thats true or even if they would be ideal in an N/A setup
ALSO
Is there anything cheap on the list below:
* Motor (shave the head and/or block to increase compression)
o Head
+ Port and polish (remove restrictions in the head)
+ Oversized valves (allow more air to flow)
+ Cams (regrind, intake and exhaust side to improve breathing)
o Gasket (thinner gasket to increase compression ratio)
o Block
+ Pistons (increase compression, light weight)
+ Crank (light weight)
+ Rods (increase compression)
Wouldn't mind having more bottom end torque/power as i don't like revving high lol..
And on a slightly different subject, what would i need to replace if i wanted to restore lost performance (my cars done just over 104,000 ks now) and doesn't seem as responsive as it was when i had it at 56,000ks
Edited by R34 -_-
heard about advancing the timing/ignition or something which is suppose to increase peformance.
cams or cam gears i think are $100-200 only 1-2kw i think and the other is real expensive but boosts 30kw as someone said above.
The R34's advance and retard the timing by themselves to the furthest point before pinging occurs. I'm sure you can hear it when you turn the car on (inconsistent idle for a few seconds), its especially noticeable when you disconnect the battery and restart the car.
Edited by R34 -_-
ALSO
o Head
o Block
2 words, 'cam' and 'belt' lol, mine is about 20 thousand over due for a change and i cant wait to get it changed, (will be done very soon) but i just changed the cam belt on my much smaller and more economical daily driver and its about a 500 dollar job but felt like a whole new car after(was 64,000 over due from previous owners) , way quicker and more responsive as the new belt puts the timing back in place
p.s. i know my car is way over due so dont grill me to bad lol, just got away on me with other upgrades and i only have time to drive it once or twice a week anyways cos of work atm
lol yea i got my belts and water pump changed at 100,xxx ks. Felt better but still not how it once was lol.. My belts were f**ked when i changed them, how the hell did u manage to get away with so many ks?????
im not sure ay, lol, im originaly from canada and nobody back home ever seems to change cam belts, but yea, i never should have let it get so far over, but i wont be driving it more then a few hundred km's before i get it changed so fingers crossed,
what oil u running? a thicker oil could help compression (lots of threads here on that) or the throttle body might need a good clean out, did you change plugs when you got new coils? cos ur plugs will be just over their limit now, i just changed mine with my coils and they were buggered
Edited by AYW550
iv tried 10w50 and usually use 10w30 but they all perform pretty much the same. Might check out the throttle body tomorrow. Only thing i can think of that would help would be to get a strip of self adhesive heat shield on the intake piping (as it is directly above the headers) and clean my pod filter as it has a few bugs and dust stuck to it.
and yes iv changed my plugs twice since iv had the car.
Edited by R34 -_-
I experienced a lot of intake pipe heat after doing my turbo conversion without a heat shield on the manifold and turbo. yes I had a silicone bend on the intake and that was the part that was too hot to touch on the underside, but after using ACL Heat Shield Material over the headers and turbo, combined with boxing up the pod filter, my heat soak issue has decreased "dramatically"!
Before heat shield, leaving the motorway and back on to the main road = a car that was gutless in comparison to how it normally drives. Now it still has that go in it.
HPC Coating your extractors and wrapping them (do it the right way so you don't go corroding the extractors) will help keep engine bay heat to a minimum ensuring everything operates efficiently, and will also help the exhaust gasses escape quickly to increase power. With N/A power, I would suggest that method should work effectively and also help increase power delivery while you're at it.
Here's a pic of my heatshield. Not much to it but it works wonders! Also covers my dump pipe as well and helps keep my turbo lines away from that hot manifold!
From this angle you can see how I've curved it over the manifold creating a bit of a barrier between the rocker covers. The N/A Manifold will probably be slightly different, and I don't know how you would go bolting down the heatshield material (I used a factory turbo manifold so I was able to use factory bolt holes).
...and a link to the product itself: http://www.aclperformance.com.au/prod_heatshield.htm
Its construction, consisting of a ceramic filler sandwiched between two 0.15mm aluminised steel sheets, gives a very efficient high temperature thermal barrier suitable for a wide variety of automotive and industrial applications.
850-900 degrees celcius. $48.50PP on eBay for a 700mm x 290mm sheet. I had enough do do the manifold and still have a couple of decent squareish pieces that I'm yet to find a use for.
http://cgi.ebay.com.au/HEAT-SHIELD-MATERIA...4#ht_814wt_1165
Edited by N-DAWG
hey n-dawg, ive been thinking of wrapping my extractors , is the only way to prevent the wrap from causing corrosion to have them HPC coated first?
i tried painting mine with woodstove paint rated to 650 degree celsius and was recommended on the can as being good enough for manifolds but its already flaking off :D
Slightly off topic but oh well, does the factory R34 Aero side skirts fit on series 2 R34? (2001 face lift) I just bought a pair today and noticed that they are a bit different than my current ones... doesn't look like the front inserts will fit
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
