  • Replies 650
ill meet you guys at lala, much closer to my house than vilis :thumbsup:
cant wait. might need a hand fitting an oil cooler this weekend.
Pussy, I'm leaving Golden Grove extra early to make it, I think you can too :(
ill meet you guys at lala, much closer to my house than vilis :P
and ill be going craigmore -> golden grove -> vili's -> mallala.
Im close to pulling out, dont know if the car will be ready on time. If not much changes a week prior to track day than I'm happy to let someone else in to my spot.
I'll take it, I've been rebuilding my 32 gtr track car for a year after a number of blow ups first at Mallala and then a N1 pump let go at collingrove on it second run. "I need some track time"
cant wait myself... :)
20% larger injectors drop in on thurs, along with the f/ic-8 ecu. tune day :whistling:
hoping the stagea feels good. does so far with the wider track rims and wheel align.
brakes will be the downer :D
I am still keen. Found a few problems with the race R33 yesterday at Time attack (brake bias, full pressure etc)
so hoping to have it more sorted for 26th. Need lots of practice with this new set up so looking forward to it.
John, seeing the 33 on the track yesterday was awesome! How many litres of fuel do you use per lap?? The amount of exhaust coming out the side is beyond comprehension!! :/
And Chad - as much as I love your 32 it'd be good to see the Stag out there (minus trailer of course :)), more family spec wagons the better!
Ah, I am not sure at this stage. We are running the car pretty rich until all sorted out.
Is great fun to drive (as you can see I was all over the track) so will have to train the beast
& try to knuckle down & get it consistent.
I am trying to learn the track at the same time as learning to drive the car so have a long
way to go. My main goal is having fun, & not wrecking the car so my first mission out there
was successful. Had a ball & car is in one piece.
There will be no point tuning the car for more power until I can drive it properly so will keep
going for it till then & when James feels I am ready we will put slicks on it & turn up the wick!
This engine is capable of some serious power & the car is very tight & quite light so when the
time is right I will certainly not be weak.
Hoping they open AIR for circuit racing again one day, because I would love a go at the straight
with a run up off the bowl............ now that would be fun.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
