Going through my window cam and working it out by the footage, the fastest times I did were 1:27's (many times), averaged 1:28 if I wasn't caught behind someone. What kinda timers are everyone using?
My 2nd off about 1minute after my dirt bath:
and my corner exit onto pit straight tank slapper:
youtube links should be right now
Thanks for the links, I was in the stocky white 33 in the vid.
Thanks to Adrian for organising a great day out, enjoyed by everyone there I'm sure....
  • Replies 650
I was the photographer out there for the morning(other commitments meant i couldent do the afternoon)
i will post some pics up here soon, was some very nice cars (was also my blue 32 in the pits incase anyone was wondering!)
cheers jamie
Jamie, were you on corner 2 just near the pit straight and then on the final corner near the start / finish line ?
last time it was dyno'd it was 170. added a couple small things since then, and the boost is a little higher (1.2 bar now, was 1.0), need to fit my ebc and adjust the timing a little bit.
fantastic day ! cheers again adrian and everyone out there.
my front pads are allllll metal, flakes and pins of metal and not an ounce of pad ! - slotted discs will be ok and fine tho.
ordered new pads as its hard to find db1250 over the counter
doing oil service right atm, ready for new pads to be dropped in tomorrow/thursday whenever delivered.
also found where the fuel map stops at 6000 - 6400rpm. needs a recalibration via a full license nistune/consult (mine cant change the logs)
Anyone who was having problems with their pads running the QFM pads.
I have done 3 track days with the set on the 180 and they (the fronts) still have at least another day left in them and the rears are bearly touched, that's pulling 1:23's as well.
Edited by D_Stirls
cant say enough about my qfm pads. they were brilliant. only lost the pedal twice during the day, and i daresay that would have a fair bit to do with my rears f**king out repeatedly.
Here is some in car from No.96
I was meant to warm up my tyres for a lap and a half and then push on. It is amazing how an R35 going past changes plans.
I use my mobile phone to video, it is mounted next to the rear view mirror, as I got to the Southern Hair pin the phone rang and stopped videoing.
enjoy
What my brand new front QFM A1RM pads looked like after the 4th 20minute session (I only knew something was up because i heard scraping on the left front while pulling out of pits into general area.
I've done 2 track days, motorkhana and a number of spirited drives on my qfm a1rm pads and rda slotted rotors all round and theyre only about half worn.
i averaged on 1.30 at mallala on shitty street tyres and running 10psi (anyhting over computer has a fit). Minimal brake fade after 6-7 laps.
Theyre great value for money, and i will be getting another set once these are goneski.
Might also depend on the way you drive i guess, some people i know chew through pads and rotors no matter what they are.
