  • Replies 650
Do we need a fire extinguisher for this?
I was going to suggest that we hire 1 shed between us to leave all our tools, jerry cans etc. At $25 it will only cost a litre of petrol per person.
probably wouldnt hurt given your history of randomly destroying things.
thats pretty unfair. you got all the facts? pull ya head in eh? fore i cockslap u and make u look even more like that dude from split enz
-D
:banana: That hurts Dave.
Thanks Ben.
I dropped the 205 off today to get new bushes, pads, fluids, brake bleed, Recaro race seat fitted (so long as the frame isn't too expensive) and a tune. My 62fwkW of power to chase down these barge-arsed Jap-crap Skylines [edit: and 200sx].
wasnt meant to offend david.
probably couldve been better phrased as 'better have it and not need it than need it and not have it.'
lol, im actually looking forward seeing how the pug goes. :banana:
Edited by scandyflick
he should nos the pug
pug + nos = better than any friggin vw jetta
haha
-D
ok ppl..
FULL payments need to be made by the end of the week. i need to forward the balance onto clem..
if you have any issuses let me know, i may be able to cover some ad get the money off u on the day..
cheers
Do I pay for the one day cams license now, or on the day? It's just I recently put in my L2 cams license and not sure if I will get it by the 26th
shouldn't you have got a temp licence when you filled out the paperwork? I signed up for mine and was out on the track the next day.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
