Temp license ran out 3 days ago, CAMS needed some extra info on medical history which is a slow process. But at least full balance has just been transferred.
Maybe give them a call and see if you can get another temp licence.
  • Replies 650
My spot is up for grabs ppl, unfortunately wont have the car ready in time.
I paid $70 deposit already, just want that back and you can pay the rest to Adrian for my spot. :down:
Edited by SkyHi_33
need the rest of the $$$ guys or clem will cancell the day..
so adrianA, adelaideprosound and no96 all want a spot so first in best dressed!
cheers
Edited by rad32
Still waiting to find out if you have to have a fire extinguisher for this track day?
Also can people suggest places to buy a helmet from? I've been to a couple of places but struggling to find one that fits properly (small skinny head but has to clear my prescription sunglasses & normal glasses). I live down south so would prefer not to travel up north but will if necessary.
Im pretty sure you dont normally need a fire extinguisher for practice days, but i would never go out there without one.
I just use a full face motorbike helmet and i fit my sunnies in no worries. Maybe try South coast Yamaha at Morphett Vale.
sorry I dont have a towbar setup on the stagea
our ford Escape does tho. . . . but Im bringing the stag lol soz
also, yeh Ive got a fire ext. setup in my wagon, for $30 for a 1kg unit and bracket you cant go wrong, albeit mine is in the rear wagon area.
for helmets, any motorbike store should have decent helmets for $100. just make sure it has the aus standards sticker on the outer back. I will bring a spare (or two) in anyone forgets a helmet
I guess I'll be wearing Draggin kevlar-inner denim jeans, long sleeved shirt, leather R-Jays jacket, flat soled shoes, helmet with helmet cam :D
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
