  • Replies 650
^^^ Sames,
Nigleswazi (spelling) is selling two kits both with Thermostats man.. I had more important stuff to buy atm but if he still has one in a few weeks i'll probably snap it up
bahaha, on nengun at the moment. theres about half a dozen suitable grex oil cooler kits.
one of them is pink.
and is worth hundreds more than the non pink variant. hilarity.
1. rad32
2. Damor34
3. HVN032
4. heslo +1
5. skandyflick
6. krishy
7. tangles
8. 32godzilla
9. joshdc
10. lukeenr34
11.writeoff (maybe)
12. r334door(s2)
13. moodles2 (maybe)
14. skyhi33 (maybe)
  rad32 said:
1. rad32
2. Damor34
3. HVN032
4. heslo +1
5. skandyflick
6. krishy
7. tangles
8. 32godzilla
9. joshdc
10. lukeenr34
11.writeoff (maybe)
12. r334door(s2)(MAYBE) just heard from my mechanic my motor is not going in till next week now.
14. skyhi33 (maybe)
12. r334door(s2)(MAYBE) just heard from my mechanic my motor is not going in till next week now.so im still a maybe hope it all comes together well. :P
  scandyflick said:
lol. not a lot. like $5-600. ill have to chat to chad about his setup, would ideally like a thermostat though...
Think i paid about $600 for my kit, no thermo though. Give Todd a call at Outlaws in the city he knows his shit about imports.
Changing oil filters is now a walk in the park :P
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25掳 silicone bend from the TB ro the MAF, but, my choice was either a 30掳 or a 23掳 (23掳 is a weird spec), so I grabbed the 23掳 one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
