im replacing the exhaust cam in a rb25neo which is from a stagea. the cam is a U6 type.
are rb25neo (stagea) cams different from rb25neo (r34gtt) cams?
could i use the r34 gtt exhaust cam in my rb25neo stagea engine?
what no. is a r34gtt exhaust cam?
thanks
https://www.sau.com.au/forums/topic/286086-stagea-rb25neo-cam-need-help-urgent/
the S2 Stagea and the R34 share the same exhaust cam p/n in fast for the RB25DET, RB25DE is different. also interesting is that the inlet cam p/n is the same across the 2.5L Neo range, DE, DET, Stagea, R34 are all the same
A few of us skeptics believe that the stock cams in the Stagea engines (S1 & S2) are 'milder' (a 'leaner grind') than R34; but they're the same engine, so just ask your tuner's advice on which cam to order - it will be the same as for the R34, and should unlock the power :)
ive spoken to three workshop and all say they arnt sure.
im looking at purchasing a second hand stock item.
im sure someone here knows what no. the r34gtt cam has on it? (stagea neo cam has U6)
i have 260deg type B poncams and i reckon the stockers are identical to all neo RB25DET's.
i'm sure i was one of the doubters that started a rumour that stagea cams might be different (years ago) when we struggled to make power expected with certain upgrades.
I think we do still struggle to make the same power :happy: But maybe it is the trans eating it all up... Look at what Tangles has had to do for his ~240kw... a turbo specialist told me that all I had to do was get my turbo rebuilt with a GT30 core and bingo I'd make 240+ kw everything standard. He was talking about R33's and R34's so a different camshaft is certainly a *convenient* theory... although I think even those cars would struggle to make that power so easily.
I still *think* the cam in an s1 Stagea is possibly different (but there may be other factors as well, such as the tuning), as the same motor in an R33 s2 makes more power (and probably more torque too, or at least spreads its torque differently) than the RB25DET in a Stagea s1.
When the s2 Stagea was released, the power and torque levels were identical to the RB25DET Neo in the R34.
I'm interested to know what you find out, beRwick_GTRage, 'cause as you have probably noticed no-one seems to know for sure what the go is with cam's in the series 2. But the idea of Poncams (ok, expensive) and a full port-and-polish (MEGA expensive - head off!) is very appealing...
On the contrary Dave the S2 seems quite clear cut: R34GTT and Stagea have the same neo engine and cams although there is not the same confidence about the S1 as yet (should be easy to check). Anyway you don't need poncams and port and polish to get to 240awkw (although it makes for a nice engine). You do need a front mount though. Just got my car back from the dyno and would have been a 240awkw car but just too much for my smic so knocked back timing etc and now have a safe 225.7awkw. Charts and details tomorrow.
thanks for the help everyone.
the cas drive on my exhaust cam broke so i need to replace the whole cam.
i was only looking for an oem replacement.
ill probably go with the r34gtt cam. i just need to know what code number it is?
because its not U6, U6 is the rb25neo stagea exhaust cam code number.
Yeah posted that before GoldZilla's post... but it's cool if they have the same cams, just means my auto must be eating lots of power... :D
OT...
That's an amazing tune, exactly the sort of tune I have been after, and I was only looking for 200rwkw... and you've got 225 at all 4 on a sidemount? series 1? look forward to details!
