Wrecking R33
after handbrake 'grip' leathery bit you hold onto. PM price (can pick up) + condition of grip (photo if possible)
Wanna keep the handbrake as a complete unit if possible mate - lever, cables etc...
hey bro do you have the front right guard front bar and bonnet and tail lights. if s how much do you want for them? my number is 0403139157
Got both front guards, no bonnet, no bar, no taillights...
how much for the complete brake setup? 500 including hubs?
Ummmmm..... NO. Complete 33 brake package, front & rear, with slotted fronts, aftermarket pads & braided lines all in excellent condition... Def not $500 sorry mate.
what colour was the car?? im after some black panels
Car was white mate
Hey got clutch? what brand, whats the condition in percentage and how much?
location?
Extreme clutch, heavy duty organic in good condition (70%) ?... Adelaide hills area
Also the car has now had Both front & rear windscreens removed, & rear quarter windows, all ready to go.
Both doors in perfect working order, complete, glass & all.
complete interior still all in good condition
Whole car has been stripped. All parts now separated & ready to go.
Sorry for any delays, but thanks for ur patience...
Still heaps of bits people!!
after a passenger side power window switch with the following pin layout
BTW the stripey 1 is where there is no pin
PM me the price if its the same
It would seem window switches & motors are one of the most common problems for 33s... I have these parts but am really trying to avoid dismantling perfect whole doors to get these small parts out & then be left with stripped doors...
Does anyone just want complete doors? That'd be so much cooler...
hey people,
Got a white 33 wrecking... most sarts still available, minus the following...
Engine, loom ,ecu...
Mirrors
fuel pump
front seats
Almost everything else still here.
Exhaust - Fujitsubo cat back
almost all interior
doors
guards
turbo timer
Full Brake package with braided lines, ebc pads, slotted rotors etc
handbrake setup
cradle
fuel tank
all windows
dash to engine bay loom
steering rack
cross member
most parts = make me an offer.
pm ur mobile number & what ur interested in & i'll respond via mobile as pm on here too hard lol
It's ALL GOTTA GO!!!
Do you have rear grill, the panel underneath the the bootlid, is it clear or painted
  • 5 months later...
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
