i had 4 sticks of 1g ram
1 snuffed it
had to remove 2 banks and run it in 2g in 2 channels for about a year
bought some ram the otherday (2 gig is ok but $70 for 2 chips is not bad to boost performance before i go gaming ram with less latency later on)
exact same partnumber but sticks are smaller
not as in width but height.
i have not booted up the pc as yet only trial fitted, and they fit beautifully
its just Kingston Value Ram 800mhz 240 pin 1gig chips
like i said partmumbers are EXACTLY the same
can i just put this down to better technology - since the release of the originals now we can haveo a ram chip with less circuitboard and has smaller processors on it?
2nd
can i hit the power button? - whats the worst that can happen... BOOM!
they are the same specs, same brand, same model...
Edited by 910trx
https://www.sau.com.au/forums/topic/286203-installing-ram/
If they're exactly the same specs (eg. 1Gb DDR2 800Mhz) there shouldn't be any issues and will operate as you had before. In regards to different sizes, yeah your assumption of improved tech and to cut costs seems practical for Kingston.
Prior to fitting the sticks and starting you may want to select optimised settings in the BIOS screen (usually pressing F1/ F2 or DEL) and save settings. Once you've got the new memory in, re-enter the BIOS screen and go to the memory menus to check if the mobo is reading all the same specs.
The worst things that could happen is one is faulty, or if the computer continuously beeps it means one of the sticks isn't properly seated or the latencies are different.
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4803291
+1 nicr4wks
As long as they are same SKU its all good.
For Kingston RAM, DIMM information is included within the SKU ie: KVR800D2N5K2/4G is
KVR = Kingston Value RAM
800 = Speed
D2 = DIMM Type
N5 = CAS Latency
K2 = Kit of 2
4G = Total DIMM/Kit size
Ciao
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4804512
New Kingston sticks are half the height of the old ones, don't worry about it.
cool they are in
except i started it up and it failed to boot after bios stage
saying it needed a boot disc
having no boot disc i dl'd a program to act as the startup disc from my fiance's laptop as it asked me to insert the disc into cd/dvd.
easy
burnt it and tried to wack it into my pc - except the drive wont open...
press the button on the front and the green light flashes, then nothing
force it open doing the paperclip trick slammed it and still wont read
any ideas? :happy:
can i somehow back it up to a usb drive and force a boot from that? :D
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4804563
if it is asking for a boot disk, the pc is trying to tell you there is no operating system (windows) found. make sure your hard drive connectors are in position firmly and that there is power to your hard drive(s). if your pc was working before you installed the ram (by working i mean going into windows), try removing the ram and try again. ram can cause post to hang and in that time the optical drive might not respond. /shrug
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4804604
well first problem solved, the hdd has two connections for the data and i plugged it into the wrong one
changed the connection and started up fine
except cdrom still wont work, its like it has power but wont open up on eject command
so i shut it dwn and thought a cold boot by unplugging it may help started her up and started to load windows got a bsod but it flashes so quick i cant read it
tried again and reqests safe mode
but in any mode including recovery it wont load, i get the same message again and it restarts on its own , requests safe mode and restarts.
ive pulled out each stick of ram and have even ran each ram in single channel (1g) to see if faulty ram was causing it but does not work still.
worst is i cant tgetht e cd to sork so i can shove in a boot disc
i'm over my head on this one...
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4805599
Check to make sure all PCI cards and other connections are in firmly.
Is the HDD/CD IDE or SATA? if IDE are they both on the same channel? Does the IDE cable have a little notch on the plug so it can only go in 1 way?
Unplug the data cable for the CD so only power is connected, turn on the computer, does the drive eject now? If an IDE cable is plugged in backwards it can cause all of the symptoms you've listed. Try this even if the CD drive is SATA.
Did you touch or fiddle with anything else while installing the ram?
Also make sure the CPU heatsink is still firmly in place and hasn't been knocked.
You can also try booting the pc with only 1 stick of ram installed in DIMM 0 (it will be small print but the ram sockets should be labeled)
Post back with results and hopefully we can sort out some more troubleshooting steps from there :D
Edited by nicr4wks
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4806514
cdrom drive sounds like mine at home, I triued all that and all it was the 4 wires for the power to the dvd drive, one of them wasn't sitting proper so it would boot up the drive but just not eject. VERY carefully push the plug in and wriggle it AND the wires (yellow black red ywellow?)
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4809352
With the BSOD; After POST, spam F8 (In between the BIOS Screen and Windows Load Screen), select the option "Disable Automatic Restart on System Failure". Once the BSOD occurs, read out the error code.
As for the drive, it is very possible that if the power is connected correctly that the servo is stuck. Use a pin to open the tray but do not close it manually, let the drive retract the tray itself and after the load is finished (the activity led on the drive has stopped), try and open again. If that fails (and once we get past the BSOD), we should try an eject command inside windows.
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4809712
thanks for the help guys i'll try the above.
sorry i have been interstate for a funeral.
before i left i grabbed the hdd out of the pc and stuck it in the carry on luggage
i took it to my old mans and i stuck it in his pc tower with just my hdd working.
started it up and told me to boot from disc etc restarted with a bsod, rebooted and came up with some windows recovery jargon
we chose the option to reinstall windows which we did (he had a win xp disk down there)
windows was installed and the hdd worked, all my stuff was on there (luckily)
returned home today and plugged it all in
straight away the same bsod and restat.
i took a vid of the bsod because it flashes so quick wiht a vid camera o see what it was.
sorry myt you may have to tone down the pc guru talk, i'm unfortunately very noob at pc hardware.
thanks for all the help so far, its great that some people are willing to help out a stranger,
Edited by 910trx
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4816775
my hdd is sata
i'm now running the original chip of ram in the ddr1 slot (so only 1gb of ram) still wont work
rom is setup with sata cable and hooked into power (pins checked they are connected) and still not ejecting or reading
the cd rom w just power will still not eject by itself, manual eject and she still wont go in after startup or when pressing in the button
the 0x24 or whatever fault code seems to relate to a hdd partition error?
is this fixable or is this going to be a take it into a bloke job - i dont want to spend money on the damn thing...
will photos of what i got be a help?
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4816988
well if it is a shagged power supply its the 2nd one i have been through in a year.
i also notice that when i turn it on the motherboard lights up a blue led and the graphics cards wind up and slow and another light lights up
this repeats 4 times before it beeps and goes into bios and the usual start up procedure
this only happens when starting the pc not restarting.
the old powersupply is no good to do a test as that sucker is well and truely blown - but can it be that simple - a power supply unit?
Might have to ask I.T. for a spare if they have one.
windows always gets to the same stage before going down so i'm thinking its os - but i cant get that to work untillthe cd rom works :D
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4817991
hmm when I've had similar problems its usually been related to the HDD being FUBAR or on its last legs :S
i hope its not that!
i got so much data on there!
trying to find a fix fo the error code is useless, all signs point to sticking in a backup disc... :)
i dont have a floppy drive...
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4818454
my work it man is going to have a look at it for me,
he solved the last BSoD so hopefully he can fix this in his spare time.
i owe him a carton of tooheys old if he gets it humming again
better than some random bloke in a PC store i guess
https://www.sau.com.au/forums/topic/286203-installing-ram/#findComment-4818642
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
