I've just finished putting a head on my RB20 which had some bigger than standard cams. Not entirely sure what they are but i have a feeling they might be 264 duration... not entirely sure on lift.
With the larger cams, will i be able to start it and get it running well enough to drive to get a tune? I started it earlier and it was idling well albeit quite lumpy for about 5 minutes. The problem is i forgot to plug in the air flow meter during this time. Now i've plugged it in but it won't idle any more.
I've got a new set of plugs to try incase running it without the afm plugged in has fouled the plugs in it. I've checked cam timing and its fine. The adjustable gears are both set to 0.
I've also checked all the obvious things like sensors, vacuum, IC pipies all joined properly.
What about ignition timing? Should i just leave it where it was prior cams? Or should it be retarded to deal with the more aggressive cam profile?
Or is it just a simple case of it's not going to even idle until i get it tuned?
I appreciate any help guys. Thanks.
https://www.sau.com.au/forums/topic/286219-starting-car-with-new-cams/
My car was fine, had a slight problem idling on the previous tune so i just opened up the throttle with the idle screw and drove it to the tuners like that.
Edited by PM-R33
Ok. well i guess i'll have to figure out why it won't even idle! :D Just checked cam timing again and its fine. I'll go and pull the plugs. Would adjusting the cam gears make a difference?
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
