Lmgt2 Nismo 3piece Mags
Hey people,
Well after a meeting with the gutter the other night :)
I need some money :cool:
2 of the mags are perfect, the other two can be fixed all that needs to be done is source some new outside rim bits- Because they are REAL 3 piece you can just take dented ones off and put new ones on :D
I havent seen these mags anywhere ever, not on a car or for sale in australia.
Honestly i really dont want to sell them but to get my baby back on the road ill probably have to.
Brand new these were $2999 USD a few years ago.
They are 17"s with Nankang NS1 235s on them.. $280 new, are in about 50-65% tread
Make offers people, i have some ppl interested already, just seeing the bid fluctuations basically.
Bid Away.....
PS .. will post pics soon as it works ?
goto the gallery and look under QLD youll see my car and the mags
cheers
Hey people,
I need some money ;)
2 of the mags are perfect, the other two can be fixed all that needs to be done is source some new outside rim bits- Because they are REAL 3 piece you can just take dented ones off and put new ones on :)
Bid Away.....
cheers
BUMP
anyone?
these rims are very very rare and look tough on any r32-34
Do you have pics?  also, can you post up a ball park figure?
new site setup, its saying the file isnt a picture or something when i try to upload. give me an address to send too.
Depends if you want all 4.
1 is fairly damaged (just outside rim)
1 is very lightly damaged(just outside rim)
2 are fine.
They are real 3 piece so if your lucky enough to find somewhere to replace or order the outside rim bit..
These are full on racing mags, they are very light and are a joint mag by Rays Engineering and Nismo. A few years ago it was Nismo's BEST mag.
I really love them, and am really thinking about buying a new set if i can gather the money together. A brand new set is around $3700-4000 delivered.
Its that or i buy 350z wheels.. or just some LENSO RS5's which are cheap
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
