Hey people,
Well after a meeting with the gutter the other night :)
I need some money :cool:
2 of the mags are perfect, the other two can be fixed all that needs to be done is source some new outside rim bits- Because they are REAL 3 piece you can just take dented ones off and put new ones on :D
I havent seen these mags anywhere ever, not on a car or for sale in australia.
Honestly i really dont want to sell them but to get my baby back on the road ill probably have to.
Brand new these were $2999 USD a few years ago.
They are 17"s with Nankang NS1 235s on them.. $280 new, are in about 50-65% tread
Make offers people, i have some ppl interested already, just seeing the bid fluctuations basically.
Bid Away.....
PS .. will post pics soon as it works ?
goto the gallery and look under QLD youll see my car and the mags
cheers
https://www.sau.com.au/forums/topic/28622-lmgt2-nismo-3piece-mags/
Hey people,
I need some money ;)
2 of the mags are perfect, the other two can be fixed all that needs to be done is source some new outside rim bits- Because they are REAL 3 piece you can just take dented ones off and put new ones on :)
Bid Away.....
cheers
BUMP
anyone?
these rims are very very rare and look tough on any r32-34
Do you have pics?  also, can you post up a ball park figure?
new site setup, its saying the file isnt a picture or something when i try to upload. give me an address to send too.
Depends if you want all 4.
1 is fairly damaged (just outside rim)
1 is very lightly damaged(just outside rim)
2 are fine.
They are real 3 piece so if your lucky enough to find somewhere to replace or order the outside rim bit..
These are full on racing mags, they are very light and are a joint mag by Rays Engineering and Nismo. A few years ago it was Nismo's BEST mag.
I really love them, and am really thinking about buying a new set if i can gather the money together. A brand new set is around $3700-4000 delivered.
Its that or i buy 350z wheels.. or just some LENSO RS5's which are cheap
My e-mail is [email protected]
I am chasing a set of track wheels, mainly after a spare set of rears, so I can replace rear tyres more easily.
And please, if you could give me an idea of what you are chasing, as I dont want to be wasting your time:)
Cheers
Steve
Drop
$1000 Firm for 2 back 17" 9.0 i think, Tyres are GC so are Mags, have original rays centre caps and hose caps.
Click on gallery at the top, goto QLD and youll see the actuall mags on my car :D
Just found a new set without tyres for $3000 locally ! :)
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
