i have a 1990 mine's gtr ,it has a rb30 block with rb26dett head n1 turbos . i have owned it for six months now i have dont a vehicle history report in all states in australia ,im the second owner in oz an i would like to know what engine internals it may have as i know the work done to it was done in japan... i would like to find out the history of the car in japan can anybody help ???
regards ,dion
Edited by oooGODZILLAooo
Any built plates and numbers in the engine bay?
Get the VIN Number and do a VIN Check here... - http://www.skylinesaustralia.com/forums/VI...ed-t128496.html
Someone can decode it for you... It might just come up as a normal 90 model GTR, so build plates and plaques are needed to clarify if it is a Mine's or not...
Just by looking at the pics, you just have a Mine's Speedo which can be put on any R32 GTR.
Check your ECU, Mine's use there own ECU's
They also have there own exhaust systems and many upgraded parts like camshafts, suspension, brake systems, and carbon fiber body parts...
So the only way to tell if it is a "Mine's" R32 GTR, you might want to take a look in the engine by taking the cam covers off to start with...
thank you for your help ... the engine number is rb30117488a axle code :r11 vin:6h91mportwhf79096 can anybody help me out with abit of info about my car ???
i need some help to try an find out a little bit of info about my car i would like to know where and what work has been done to my car how many owners ect" the engine number is rb30117488a axle code :r11 vin:6h91mportwhf79096 can anybody help me out with abit of info about my car please ???
You'll need the chassis number BNR32 etc etc so we can check it on FAST. Are there any other marking around the car to suggest what Mine's parts are inside it?
Your best bet would probably be to contact Mine's themselves, although don't be surprised if they haven't kept records going back that far.
  • 2 months later...
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
