hey all,
I need to fix my turbo which has recently blown - and was looking at reconditioning my std turbo with steel wheels and a high flow.
Can anyone recommend a place to do this in Vic?
Has anyone done this and had good results?
How much can I expect to pay (looking at keeping costs to a minimum)??
I really need urgent help with this one.
thanks heaps guys.
https://www.sau.com.au/forums/topic/28623-turbo-hi-flow-in-vic-help/
http://www.r33skyline.com/For_Sale_GTS.php
This car has a stock turbo which has been high flowed by ATP in murrembena, cost $1800 it has been bored out a bit and has steel sierra turbines.
Car is currently making 225rwkw on 14psi, with injectors and 18psi 250+rwkw
you can also give Dennis at P.E.T Mods a call on 0425 799984 or (03) 9464-4225.
he has done a couple of these with good results on a VL and a skyline.
tell him Gorjan (RS500) referred you and he'll help you out.
ATS is a lil doubtful
hear bad stuff
http://www.exclusive-auto.net/forum/viewto...opic.php?t=6692
why does it cost so much jus to hi flow the turbo
i mean they are using the original turbo and jus shaving and machining it a bit
btw if u hi flow turb
what other things would u need to change?
injectors? ecu?
Kyp at A.T.P.
1198 Dandenong Rd Murrumbeena VIC 3163
ph: (03) 9569 4764 (Advanced Turbo Performance) I am not sure on prices, give him a call
For around ~$1800 Kyp can rebuild your turbo, install a T3 compressor, Sierra trim cut back exhaust steel wheel, bore out your housing for them to fit, new core and clean up the housings and youll get a perfect street performer.
The only thing he reuses is YOUR compressor and exhaust housings.
Everything else is brand new
ps: bare in mind, alot of workshops SEND their turbo to ATP for rebuilds or various other specilised turbo rebuilders
Or pump in about $700 more and u can get yourself a custom built turbo that is external gated and take u to over 300rwkw easily
why would you want to put a T3 compressor wheel into your turbo while it's being rebuilt/hi-flowed?
and, that sounds a little pricey for that wheel combo u state.
Ă—
Ă—
