I think i have decided to sell up my gtr and all its parts after waiting far too long for the engine to be built and i am pretty much over the car and have had enough..
i will however have it finished for the buyer..
I bought a Used R34 N1 motor from japan waited months for it to turn up..and then bought a long list of parts to go with it..
R34 N1 Block Crank head etc.
Mahle 86.5mm Pistons
Pauter x beam rods
Tomei 11.2 270 degree cam's
os giken cam gears
tomei baffle
Jun Oil pump.
Nismo complete gasket kit
Supertech springs
Supertech valve guides
Supertech titanium retainers
Ati Balancer
Os giken rc3 Clutch (suits my r34 getrag with nismo spline)
Arp studs throughout
Head has been ported by a very good head machinist who has been building very serious rb30's rb26's sr20's for many many years.
Was done for Circuit spec's tho will suit other applications also. built to handle serious power..
Can also supply my Turbos which have been rebuild 2000km ago similar specs to Hks GT-RS but without the lag.
I'm looking somewhere around the $20,000 mark. and another $2500 or there abouts for the turbos.. and another $4500 for the gearbox, clutch and gearbox will be sold together..
alot of money has been spent on parts, and is a very good price for someone wanting their car reliable with bucket loads of power.
  • 2 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
