just wondering...
ive been told that the engine seals start to wear out on the GTR motor's at around 100-150,000km's is this true? and how can you prevent this or what happens when this occurs....does this mean a whole new rebuild?
cheers
P.S this might be a load of shit i dunno....just heard it from a few people one of the guys owns a FD series 8 rx-7 though( could be abit one eyed)
Edited by Fat-magz
https://www.sau.com.au/forums/topic/286302-engine-seals-on-gtrs/
Sounds like a myth, it's a racing engine afterall not a taxi engine.. about 150,000km you are probably looking at a rebuild anyway, though only if compression is below certain limits for that specific engine (rb20, rb25, rb30 etc are all different)
wats good compression for a r33 gtr? do you know
cheers
the R32 service manual for the RB26DETT specifies the cylinder compression lower limit as 121psi, with no more than 14psi difference between adjoining cylinders.
Front crank seal started to leak on my r33GTR eng a few years back, pulled balancer off and changed it in situ. No more leak. Rear seal was still good.
My 33 RB26 eng comp tested with stock cams at 155-160psi.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
