swaps for my ceffy... sr20 s15 engine and six speed gearbox... all engineered with full r32 gt-r interior (as in front and back seats)... let me know.... cash adjustment if necessary
i just need a larger car to move shit as i have my own restuarant
cheers
Swap for my 1.3lt Toyota Starlet Turbo? I originally want to swap for a stagea so here is a good chance. Car now has T25turbo, Stainless Steel manifold, Evo VI cooler :(......just to name a few. A project where i've just finished.
sorry WEST im gonna have to pass on you......... Drift Monkey possibly be interested would you be able to post some interior pics and some under carriage photos please cheers mate.....
Thanks for all your interests
wanna swap for all this if so email me [email protected]
R33- it has 97000k on the clock, auto, factory turbo, big front mount intercooler, blitz blow off valve, hks turbo timer, pwr mirrors and windows, central locking, set of 17's that are on it in the photo with ok tyres and a set of stock nissan 16 inch with not so good tyres, clean interior, little tear in driver seat, front bar and left guard are white and the rear left quarter has a ding in it but i don't know how it got there because i bought it like that. and i have some new paint mixed up to respray the front. its regoed untill jan. 2010.
VL CALAIS- disc to disc lsd with 4:11 gears, auto, stock RB30 just needs a dizzy but i think i have a couple of spare ones,custom seats but front driver seat is ripped, good grey velour calais door trims and hood lining just needs to be put back in properly, complianced factory turbo, and for race seats and cage i think, 1 or 2 of the wheels in the pic are cracked from my mates brother taking his stateo up the gutter. and some low life stole the nose cone out of my mums garage so it would need that and a new sunroof because someone broke the old 1
VL COMMODORE- all brand new bushes+ pwr steering rack and pump+ adjustable panhard rod+ super low king springs+ gt gas shockies+ wheel bearings+ slotted front rotors+ new unis+ the 5 spd has been rebuilt+ the engine has been fully rebuilt done f**k all k's, it was bored to a RB31(3.1 litre) with a vl turbo crank, forged ACL race pistons and rods, ported and polished head with heavy duty valves and double coil valve springs. put a metal head gasket on it and it will handle a turbo and or nos all day long. i tapped a truck and rippled the nose cone and front guard so i was goin to put everything in the calais. i took the dash out and the pedal assembly and put it into the calais and that was as far as i got
I am selling a 1997 NISSAN STAGEA RS4 Red. Owner is a mechanic and has been well looked after.
DETAILS
- Major service just done
- Auto
- Rego till Dec 09
- 103.XXXkms
- RB25DET
- Lowered
- 350Z wheels
- Boost Guage
- HKS split dump pipe to front
- Custom stainless steel catback exhuast (Receipts for it)
- High flow metal cat
- Apexi N1 tip
- R33 GTR front seats (Mint condition)
- Front mount cooler
- Front inner door inserts Vinyl (red)
- Major service done
- DVD player
- White face cluster
- BOV Type 2 turbosmart
- Front strut brace
$10,500 ono or open to swaps
Has reciepts for everything done to it including import papers and every owner in Australia (he is the 3rd)
Contact Phil on 0421 130 167 for more info or pm me
Cheers :)
What do u think about my 4 door skyline for a swap ?
http://www.skylinesaustralia.com/forums/4-...33-t295694.html
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
