The guys that fitted this kit, did you get an increase in performance?
i would also like to know what performance gains people have gotten with this kit..
Is it much more laggy?
  • Replies 42
wouldnt the GTR cooler be better than this as its already that size if not bigger and flow better due to the bigger end tanks??
jet thank mate!!!! i just install the intercooler look mad feel mad....very nice looking thank...dude
so you just installed it?
Can you feel the difference... much lag?
I would imagin there would be a bit more lag from an rb20?
Ming come out for few runs this weekend.
We got DC5, 200sx, and Supra TT and maybe few others.
druzilla32, whether there is lag or not really depends on what sort of turbo you have and how your ECU is tuned. Its got nothign to do with the intercooler. I dont have any lag problem at all because my car is tuned.
The intercooler makes your pod sounds louder and nicer. It does not change the sound of your BOV.
I can show you mine if you live in sydney.
the only mods i have are catback (get my dump/front and highflow cat in a day or 2) pod filter and boost at 14psi. I dont mind if the turbo slowly shits itself as i plan to go bigger. I am aiming for about 180rwkw.
If i get a reading of 14psi without the fmic.. Will i get a higher reading after its hooked up, say 16psi? Should i turn the boost down then or is it ok cuz the turbo is still only pushing about 14psi..
I want it at about .9bar as i dont often hit boost during the day and at night rarely go over .6bar
If your using a bleed valve you will have to turn it down because the standard cooler drops a few psi where as the hybrid wont (i assume) So if you are running 14psi you turbo is proberby pushing 16/17psi just to make 14psi at the engine. If you have a controller you wont nedd to worry about it.
Jet,
Would you be able to summarise the DIY installation please, including info on cutting the fan blades/ front bumper bar if applicable.
I need to factor in the installation cost in case I can't do it myself.
Thanks mate.
oops forgot to ask you this, Jet.
I have the factory electric fan for the A/C unit, would this need to be moved/ modified for the intercooler fitment ?
eek.. i hope not... I havent realy thought about the stuff i may need to remove.. All i knew is that i wanted a fmic.. so i got one...
I havent seen it yet.. Its getting delivered today :) Im so excited.
So yer, what has to be removed for the cooler?
Any other hints for installation you may want to share? Im gona give it a chop on the weekend.
I fitted my hybrid to my r32 last weekend the only things i needed to modify were:
1. The fanblades and shroud need to be trimmed for the top pipe to fit.
2. Both top pipe and the cooler bottom brackets were way off so i had to make my own.
3.Had to give my gtr front bar a haircut for that to fit properly too.
Other than that it was all good. Took about 8 hours and 10 beers :) It was the first one i'd done.
Well done Ronin. It took me the same time for my r33.
You car will breath much healthier now. Did you notice much power difference?
123toc
Pls go to the link below to get some picture. Although its for R33 but it will fit a r34.
https://secure-krakatoa.commercevault.com/p...OOLER%20KIT.htm
i put mine on last saturday.. started at 12 finished at 6.. That included playing a few card games and some pizza :)
I can realy notice the difference when i am by myself at night time... it seems to hold boost a lot better now.. from 4500rmp onwards its way better, + i seem to get better fuel consumption, ALSO i cant hear my car missfire anymore.
I didnt have to trim the front bar or anything. I just moved the horns up a bit.
I will post some pics of it later.. looks awesome. Thanks Jet!
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
