  • Replies 59
I see your Raptor Jesus and raise you an ice age. There isn't any pics of it because raptor jesus and his Canon SLR didn't survive it.
5 Aces, bitches.
raptor jesus needs no slr, raptor jesus has a photographic memory.
whole deck mofo's.
invalid, way too cold for the diesel, 4x4 wouldnt start.
ba-bow LOL. nothing a few additives cant fix :P
Glowplugs bitch!
+1 right there
4WD limiter bash apocalypse. that should crack us out of an ice age
*insert video of the GQ on the dyno at Graham Wests earlier in the year and you'll understand*
What you talking about matty....your GQ completely deplete the whole Ozone layer...it was ROR worthy
but to simplify,
raptor jesus > all.
Can a raptor jesus do this?
and remember -
Outer space exists because it's afraid to be on the same planet with Chuck Norris.
Chuck Norris wins
Some other useful facts:
When the Boogeyman goes to sleep every night, he checks his closet for Chuck Norris.
Chuck Norris doesn't read books. He stares them down until he gets the information he wants.
There is no theory of evolution. Just a list of creatures Chuck Norris has allowed to live.
Chuck Norris does not sleep. He waits.
Chuck Norris is currently suing NBC, claiming Law and Order are trademarked names for his left and right legs.
Chuck Norris is the reason why Waldo is hiding.
Chuck Norris counted to infinity - twice.
There is no chin behind Chuck Norris’ beard. There is only another fist.
When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down.
Chuck Norris is so fast, he can run around the world and punch himself in the back of the head.
Chuck Norris’ hand is the only hand that can beat a Royal Flush.
Chuck Norris can lead a horse to water AND make it drink.
Chuck Norris doesn’t wear a watch, HE decides what time it is.
Chuck Norris can slam a revolving door.
Chuck Norris does not get frostbite. Chuck Norris bites frost
Remember the Soviet Union? They decided to quit after watching a DeltaForce marathon on Satellite TV
Edited by 4door_Sleeper
Chuck Norris worships Raptor Jesus, he lives his life trying to attain the amount of pure awesomeness spewing from the raptor jesus. so therefore, Chuck Norris < Raptor Jesus
btw, this thread needs moar:
where is your proof? I have photos to validate my claims, what do you have?
    • Welcome!  Car sounds great, anypics ?
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
