Right guys this is what i need. I have the spacer /z-tube / k&n drop in filter. I need those installed. I also havent done any kind of a service on my car and its nearly at 70,000. I can supply the parts unless you can get them cheaper . All i need is some one who knows our cars and cares about our cars to install everything i have.
Im in sydney and can travel to your door. Not sure how long it would take but i guess if u have the right tool and enjoy working under the hood this is for you.
Personally i spill the oil when trying to top it up so its not my field.
Im willing to pay so PM your quotes and il get back to ya.
https://www.sau.com.au/forums/topic/286356-service-and-install-required/
The drop in filter you can do yourself. It's a 2 second job to unclip and remove one, and fit the other. Everything else is also quite easy, but I wouldn't trust myself to do it since I'm useless with tools.
Try The Engine Whisperer. Andrew's done a bit of work to my Z33 in the past (he fitted the catback exhaust and the Popcharger) and he's very good mechanically.
If I remember correctly manda lives down south. If you want a workshop close by, try IS Motor Racing in Rockdale. They used to look after the Auto Salon 350Z, and I know they've got quite a few Z/V customers now. Indy's got a pretty good rep as a mechanic.
Otherwise, Pro Concept for sure. Call Joshua - its easier than emailing him.
Edited by scathing
i wouldnt have an idea about the price, tho however no doubt he can do the job for you.
always call him, because he is quite busy.
Spoke to josh today at pro concept. Very nice guy easy to talk to. I was suprised at the prices he quoted me.
He quoted $190-$260 for a minor service depending on the oil
And for the install for the spacer / filter / z-tube was $120
So all up under $400 for everything i guess thats not too bad for a good professional job.
Also any minor service includes a free ecu scan so i get that too.
ecu scan?? you mean for error codes? lucky i can do that myself now with my scaner..
as for the filter and z tube that would be really straight forward...
yes on the pro concept website it says free ecu scan with every minor service. As for the filter and tube like i said no idea , i put petrol in and go .
No offence but the air filter replacement on a V is not a 2 second job. I thought so too at the beginning but it involves removing the whole air box before being able to replace the panel filter.
Here is a DIY video:
If you are doing the filter replacement, the Z tube can be installed at the same time since you have got everything out already.
Seriously? On a 350Z you just unclip the holder and pull the panel filter out with it. Having to pull the entire airbox out is some seriously bad design.
Just having a look at this pic:
Is the Infiniti setup the same as the Nissan one?
Aren't those 2 clips on the middle of the airbox (between the "Power Duct" and the lowest arrow) all you need to pull open to replace a panel filter?
I'll have to watch the vid later - no access to YouTube from here.
Setup looks identical to the V and has those clips too but you won't be able to retrieve the filter until you have removed the airbox. Maybe you should go to your Z and try removing the filter. If you are not back in 2secs we'll understand :)
Maybe you should go to your Z and try removing the filter. If you are not back in 2secs we'll understand :/
I've got a pod filter on the car now.
To pull out the stock panel filter element was a case of undoing those 2 lips, and yanking the holder out.
I just watched the video. Wow. That is disgustingly bad design. How can Nissan make a car that's that hard to service? Especially considering the Z33's airbox is nothing like that?
In the Z33 there's no need to remove the airbox from the car. I can't find any photos of the stock Z33 airbox to illustrate, but here's an exploded part diagram:
Part (2) (the holder) keeps the filter in place, and has 2 clips on the top. You leave the airbox in the car, undo the clips, grab the handle between the two clips, and pull the holder out of the box.
For people looking at retaining stock airboxes in their V35 and retaining a drop-in panel filter, I'd look and see if Z33 ones fit. It'll make the job of servicing it easier, if nothiing else.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
