Ok, you guys wanted to know. I use Speedworks as my prefered workshop, I've used them quite a few times for bits and pieces as well as general servicing (oil change, etc) and I'm more than happy with their work and knowledge. They've tuned some pretty powerful beasts, have a look at:
http://www.speedworksauto.com.au
Recently they did my boost gauge and boost controller as well, in the near future they'll be doing my trust front mount cooler and probably a greddy e-manage ecu. In the distant future a trust turbo, trust 550cc injectors and a larger fuel pump to suit. They're more than happy for any of you forum members to drop in and talk shop as well as your work as required, when you do drop in mention that I sent you (rob with the black r33 skyline) and they'll extend to you the same level of service. They have huge amounts of knowledge, one of their most recent beasts is a 11.7 second quarter mile R34 GTR and it was still not tuned completely.
Anyway, I'll think you'll find they are quite serious about their work and are one of the more reliable places around.
Rob
https://www.sau.com.au/forums/topic/2864-the-big-secret/
Originally posted by rob77
You'd have to speak to them to get an idea, but I get them to put mobil 1 in my car and thats what they recommend. just tell them I sent you (speak to ivan or john) and they'll look after you.
Rob
But i thought you had used them for a service before....... how much did it cost you?
https://www.sau.com.au/forums/topic/2864-the-big-secret/#findComment-50470
I had the oil changed and the filter as well as having some fabrication work done on my stock bov to block it off from the manifold but still leave it on (ie: a metal plate). So all up it was around $250 (mainly due to the time involved in making the metal plate). The oil from memory was around $50 for the 4-5 litres and oil filter was $10-$20 and I'd say it would have taken them around an hour to change the oil and check a couple things over so its around $50/hr labour plus your GST, might be dearer than your local mechanics, but they work on performance cars all day everyday, not family sedans. I wouldnt go to a certain large chain of mechanics after they worked on my wifes hatchback, completely stuffed the brakes and charged a fortune and another guy reckoned it took him close to 6 hours of labour to remove and replace her clutch @ $40/hr.
Rob
https://www.sau.com.au/forums/topic/2864-the-big-secret/#findComment-50504
My personal opinion is you will find them both good. Jan and Hanson at X Speed have built some killer rex's and evo's as well as skylines.
Things have changed a bit at Speedworks with Basil Chow now running the w/shop and I have found him to be very competent and knowledgeable as he has a gtst RB26 he is building.
Trouble with them is getting hold of John or Ivan.
Also some of you may knock them but CRed w/shop under Lumpy Campbell is another one to consider.
https://www.sau.com.au/forums/topic/2864-the-big-secret/#findComment-50845
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
