R32 GTST, 92 model, Burgendy, BN front and rear bar, GTR bonnet, side skirts, no spoiler, excellent paint job
Car is complied and can be regod
No engine/gearbox or engine wiring loom/ECU
Large oil coolers with remote mount filter and full braided lines
Also has oil catch can
PS pump (no hicas) custom PS resivour, ps cooler with braided lines
Supension has all bushing replaced with Whiteline, whiteline swaybars, custom front caster rods, rear camber arms, rear toe arms and Hicas lock out. Car has coilovers with many different springs as well as Bilstein shocks and standard shock. So between it all you can get a decent set up for drag, steet of circuit work. Also has front and rear strut braces and adjustable front upper arms.
Front wheels are 17x8 with new Yoko Advans, have the rear wheel to match in 17x9 just dont have any tyres on them
Have 4 of the polished wheels, 16x8, 2 with MT drag radials and 2 with BF drag radials
Brakes: Front: 32 GTR with new sloted DBA rotors and racebrakes pads
Rear: Sloted rotos with racebrakes braided lines all round and as new pads
GTR diff centre shimmed with GTR driveshafts and modified hubs
No fuel system
Inside, Half cage, Velo race seats x2, Sparco 4 point harness x 2, Sparco Steering wheel, stripped out rear with no carpet/rear seats
Autometer boost gauge
I did most of the work myself at our engineering workshop including cage/ sus parts etc but all parts are in great condition.
Looking for around 4-5 k depending on what you wont included with the car, really is a great car I was the first Aus owner and I have had it for about 9 years now. Has not been doing much for the last few years as was a project but now dont have the time/money for it. All needs is an engine/box and wiring for the engine and its away.
Have a few parts out of the car for sale so can do a good deal if you wont other stuff to build it up into the beast it was, please see other add
http://www.skylinesaustralia.com/forums/Bu...ds-t286427.html
Im in Adelaide but willing to move car where required.
Consider looking at swaps etc with stagea or 4 door something
Thanks Clint 0418815974
[email protected]
Yes has been regod in SA, and is fully complied. I can just renew the rego here in sa and they will send me out the sticker
has/can this be registered?
i can see an sa plate in the last pic, but there are some dodgy carnts around
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
