I have discovered that I have an oil leak at my oil filter sandwich plate in my R33 GTR. It must have been happening for a while as there is dry greasy oil all over my front diff and is also spreading down my sump. I have put the car up on blocks, removed the bash plate to have a closer look but things are pretty tight given the sandwich plate sits just above the front diff and behind the engine mount and I cannot get a good view of where the leak is actually coming from. Working from the top, I removed the PCM valve and extended my arm under the sandwich plate and it was quite wet with oil, however, not sure if the leak is from the earls hose connections or the sandwich plate itself.
I assume these sandwich plates screw on like an oil filter and have a rubber o-ring to seal correctly?
Has anyone had this problem?
Yes the sandwich plate has a machine lip where an O-ring sits onto the block to provide the seal. You might have a worn O-ring giving you a leak, as there will be oil all over the hose if the connector was busted.
Thanks for the update. Certainly all points to the sandwich plate at the moment which is the part that is covered in most of the oil. Either it's the o-ring or whoever installed this before I took ownership of the vehicle didn't tighten it enough.
I doubt it's the tightness, as the oil pressure will help make the seal (similar to an oil filter).
Although, it could have been over tightened. I think if you over do it the seal can tear.
Oil leaks huh. Pain. I think one of my rocker covers sprung a leak recently :)
unfortunately the sandwich plates are a common leakage point, they are tricky to get on straight (sfa room) and you should never over tighten as there is a rubber seal.
last time i had a sandwich plate leak i took it to a mechanic and paid them to go through the pain. some jobs aren't worth it
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
