Ok I have a s1 rb25det in a 240sx. Ive been driving it with no problems for about a year now. Then All of a sudden my car start staying around 210 coolant temps in F. So I checked my timing and found that the only way I can set it at 15 btdc is with the cas all the way CCW?? What could cause this??
Edited by meet07
https://www.sau.com.au/forums/topic/286529-cas-all-the-way-ccwwhy/
Some timing lights show double the real timing when you use the "timing loop".
The safest way to check timing is to insert a spark plug lead between coil #1 and its plug, and check the timing "old school".
My freind told me about the redline product water wetter. He told me how he put it in his ride and temps decreased. Well I have been seeing my temps around 210 for about a month or 2 and kinda wanted to lower the temps. So I did a coolant flush and added the redline water wetter. I filled the rb with the front jacked up and let the car run until the thermostat opened. Cut the car off for about 3 minutes and crunk it back up. I repeated this about 3 times. Then I wanted to check my timing b/c the other day I messed with it and wanted to double check. When I checked it I noticed that the timing was reaing 0 degrees. So I adjusted it all the way ccw. Took it for a spin and it felt good but when I brought it back home to idle the temps reached 210 again. 2 weekends ago it climbed over 210 after a long drive and when it did the rpm went from like 1100 to 16-1700 rpms.
im confused b/c i have never had a car act like this. It doesnt make sense.
Edited by meet07
Are you using the factory engine fan, or a thermo fan?
Is the thermostat working correctly?
Have you been using corrosion inhibitor in the coolant? The blades on the water pump have been known to disappear when inhibitor is not used.
Open up the air bleeder (near the pressure regulator), turn the heater to max hot and jack the front up so the radiator is the highest point again.
And are you using a fan shroud on the radiator?
more than likely 2 different issues here. the timing issue could be caused by the timing belt jumping a tooth, or possibly by the CAS being dodgy. if you can try someone elses CAS is the easier of the 2 options, but it isn't unheard of for the timing belt to be out by 1 tooth.
the temp issue could be caused by the timing issue but could also be caused by something totally unrelated. it could be that the radiator is blocked, the thermostat could be stuffed, there could be air in the system or the water pump could be worn out.
  • 6 months later...
I fixed the coolant temp issue by replaced my old fan setup with the 210/220 fal fans...
But im still having the ccw cas sensor issue. I recently installed a z32 maf and realized that the car was breaking up around 10-14psi. I put the timing gun on the crank to find that my timing was to the left of the TDC mark. I lowered the idle to 900 and checked timing and it was at the TDC mark but not 15 degrees??
-I checked to see if maybe I jumped a tooth on the belt. That checked out fine!!
-checked to see if the key was broken off in the cas...good!!
Now im stuck? With the cas ccw(15 degrees) on 14psi she pulls super hard!!! but if i place the cas in the center where it is suppose to be its breaks up due to the timing being retarded...
please help!!
Edited by meet07
  • 2 years later...
Yes I did use the timing loop. However the timing is set correct, as it would be pinging it's head off if the timing was advanced too far by being on that stop mistakenly.
So I'm sure it is at the correct 15∘ BTDC. I just want to know why it is hard on the stop to get the correct timing?
Is the cause the tune in the Power FC? Is it the Poncams? Is it an incorrectly installed timing belt?
Unless the exhaust gear is extremely adjusted
If u could hear the pinging from out side its extreme and too late.
Trust me, get an ignition lead and double check it.
For the sake of 10 minutes work.
The timing loop has always been 15degree's or so out when i have tried it
The loop is there for factory & dealer use. All computer equipt vehicles with CAS or a dizzy have a procedure to put the ECU in a timing limp mode, only then can ignition timing be properly adjusted. Nissan use consult to tell the ECU to go into timing mode. On most older ECU cars, you simply bridge two terminals out (engine speed very noticibly drops), adjust your timing, pull your bridge out & your done. Im not sure if there is a procedure like this for the consult plug. I haven't found one yet anyway...............
Sounds easy eh...
Still doesnt make the timing light read the loop correctly.
Sounds easy eh...
Agreed Jez.
The loop WILL read correctly, once the ECU knows it's in timing adjust mode. RPM drops as the ECU disables advance as compensation for no vaccuum advance as on older dizzy equipt ECU vehicles (where you have to disconnect & plug the vaccuum line before bridging the plug). Unless this is done, setting timing is a hit n miss exercise. I suppose this subject has been covered extensively already!
U are incorrect thinking the timing loop will change.
What i mean by this is setting the ecu into "timing mode" just locks the timing solid so it doesnt change while u are setting the base timing, by using consult etc u can read and match, eg: if the consult shows 5 degree's then set the base timing at 5 degree's. if 15 set at 15 etc.
The issue with the timing loop is alot of timing lights can't accurately read/pickup the signal. The loop wire is just an extension of the wiring going to the cylinder 1 coil signal wire.
So theoretically the loop wire should read exactly as if connected to a coil lead when run off cylinder 1 coil.
An ignition lead is 100% accurate as the timing light is designed to read it and does so easily.
You are correct that the ecu should be put into timing mode
This conversation has morphed away from my original question. I am happy that I have set the correct timing of 15 deg BTDC, the issue is that my CAS is all the way to the stops to achieve it.
I've since been told by my mechanic that we can change a setting in the Power FC to get the CAS in a more normal position (I assume it to advance the whole base timing by 10 deg or so), but is this kosher?
It has been on topic the whole time.
I will ask it again tho, have u checked the ignition by using cylinder 1 with an ignition lead?
It will take u 10 minutes to do and then u can be 100% certain u are correctly reading the timing.
There should be no need to change any settings in the power fc to try and bandaid the issue
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
