can u make like a switch so that u can have rear wheel drive or all wheel drive in the gts4 32s
As far as I am aware you can, IF you pull the fuse out for the 4wd you will be stuck in rwd. So wiring in a switch may be a possibility... Not a bad idea as GTS4's are a pain in the ass to get off the line
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4807901
Yes you can.
You wire an inline fuse to a switch and crimp spade terminals where the original fuse location is situated in the engine bay.
Just be aware that to get back into AWD, you have to flick your switch back and turn off the ignition to reset the feed.
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4807926
to add a note, there are two fuses that will disable the 4wd. One in the engine bay that kills the power to the hydraulic motor itself, and one in the interior that pulls power from the control module (but this also disables abs).
I put a toggle switch on the motor feed, and a momentary on the module feed. Switch, burn, switch and push button and good to go. Don't really like the idea of turning off the ignition when you are meant to be staging. Toggle is good for when I want to play but still have abs.
Edited by heller44
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4808752
