Hey guys,
Where is the best place to go to get roof racks for the stagea (in Melbourne)?
cheers
Give Roof Rack City, in Artarmon (Sydney) at call and ask them the model number for the Thule rack. They will tell you who to visit in Melbourne as they are the importer of Thule for Australia.
Cheers
Andy
I believe that Repco sell Thule roof racks.
Once you have the part number, take it to a Repco.
Remember that each Repco store price items independently, so if you don't like the first quote, try another store.
http://www.roofcarriersystems.com.au/ ?
Everywhere sells Thule products. Depends what suburb you are in and how many phone calls you want to make to save a few dollars.
  • 9 months later...
Looking at buying over the Internet a 2001 M35 arx with no roof racks.
how do I install the two bars that run longitudinally on the roof that some models seem to have.
Is it a quick easy job?
Are these bars expensive or difficult to source ( eg a wrecker)
thanks
I'm assuming you mean the black rails down the sides of the roof? If so; all m35's have these. There are two small caps in each rail, these pop out and reveal a plate with two captive nuts. The end of the roof racks pick up these bolt holes to attach. The O.E. racks have a flat plate that you bolt through, but Thule's or Rhino's normally use an extruded side rail to mount. A section of this extrusion, bolted to the rail mount, will now accept the roof rack of your choice.
Thanks for the info.
Any idea of a ball park price for these O. E racks or a link in brisabne (not currently there yet)
Edited by samuri
I would guess O.E. would be more expensive than aftermarket (last lot I bought were around $400)and, the range of accessories for aftermarket is far superior. Thule and Rhino are a nice areodynamic profile which makes them much quieter.That, and the O.E. are so ugly, it hurts my eyes to look at them...
Edited by Daleo
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
