Engine Tuning in Australia
56 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys,
There has been a little discussion over on 350Z-Tech about ECU Reflash/Tuning of our cars. As we share the same heart (engine) I thought I’d extend the little fact finding exercise I started over at Tech here to better gain an understanding of what VQ owners would want from a tune if it was available. This will assist in determining if there is a business case to develop and take to a tuner (ie UpRev with Osiris). This should only take 2 minutes and I would appreciate your input.
Parameters that the tune will include at minimum:
- Up to 5 Maps on cruise control equipped vehicles
- Idle RPM
- Speed Limiter
- Electronic Throttle Control to achieve Wide Open Throttle at all speeds.
- Rev Limiter
- DTC disable
- AFR Targets
- Fuel Compensation
- Ignition Timing Advance
- Cam Phasing for equipped vehicles.
Additional questions (optional):
4. What features in would you like to see in addition to those listed above?
5. What on-going support would you like to receive from the tuner?
6. Any other comments.
https://www.sau.com.au/forums/topic/286582-survey-ecu-reflashtune-in-australia/
Thanks to those for their replies to date. It is very beneficial knowing what the community is looking for before approaching the tuner.
If you haven't replied and are interested I encourage you to do so.
Thanks,
one thing that i'm really interested on ECU tuning features is the raising Rev Limit and Speed Limit removal as well. the rest is just the same thing A/F ratio, ignition timing, etc, which unichip can do.
I've looked at a couple of reflashes in detail and narrowed the list two products that would be best for the Aussie market. Both offer these features.
How much HP/KW gain could be had from a ECU tune? Say with a plenum, intake and exhaust?
+1 to pw350gt.
It all depends on your car. Tuning doesn't create power, it unleashes it. Tuning is efficiency and a by-product of that will be more power. So if your car is in good shape, and there are gains to be made, there will be gains made. Add more parts that add a mechanical advantage, and the tuning will net you even more gain.
Edited by Aust350z
if i got an extra 10rwkw for $750 i would pretty happy :(
I'm pretty sure my dyno runs (with a cat-back and Popcharger) pre-ECU and post-ECU netted me around 10rwkW on the Z33. Note that was with the stock 6600RPM cutout, since I use a Unichip and hadn't reflashed my ECU yet.
I might have found a bit more if I could have revved the engine up to 7000RPM back then since the power curve didn't really fall away that much at the end of the graph.
  • 1 month later...
  • 2 months later...
I'll be following up early in the new year. Tuner shop approached was interested but requires them to get more involved.
I'll also add that the chosen reflash is Orisis from Uprev. Comes in three options (a) flash; (b) standard; © tuner. More info for those interested can be found at www.uprev.com
Uprev is also very keen to establish a Pro Tuner(s) in Australia.
Edited by Aust350z
let me see what i can do i know someone who may be willing to become a pro tuner
I'm all for someone working on getting this to the Sydney market :geek:
My goal is to have a Pro Tuner in Melb by end of March 2010.
Sounds excellent - I am most interested in a local tuner. Would it mean we still purchase Osiris directly from UpRev or from the local tuner (wary of the usual USD-AUD crazy markups, especially with the strong dollar at the moment)?
From your enquiries, is there any reason we couldn't buy the Tuner version of Osiris and use it on our cars already (not that I am saying I would be able to tune it). Is it currently compatible with JDM cars or will the software need modifications?
Would purchase from the local tuner at an AUD price. I wouldn't worry about this just yet :blush:
I would need to check comparability with JDM cars now but it is one of stages to reverse engineer the ECU to local markets (ie: Australian Z33). If ECU already compatible then nothing stopping you buying now. If you get the Tuner though you forgo Uprev support.
Edited by Aust350z
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
