Sau Nsw Oran Park South Track Driver Training Day
haha good stuff. you'll really notice the different running on semis too.
I think the biggest difference will be getting rid of that "knock knock knock" noise... ROFL
The fun starts tomorrow...
Rip old motor out and get the head setup off it...
Then I gotta wait till I can pick the block up mid week... Then put it back together...
Then see if it runs... Then rip a skid... See if it'll still run... Then see if it goes on the day of race day... ROFL
17 day dead line to replace a motor... And the only thing I've got at the moment is a dead motor... ROFL
  • Replies 389
Posted Images
Nope, you don't need to be a member of any club, but membership to SAU-NSW can bring you cheaper entry into future events we hold, if you're keen, so it is worth your while!
Just being a part of the club is worth while, not just for cheaper events.
Mind you, the cheapened Merch is also well worth it... :O
damn it....
Weekend before Bathurst so we don't know if Dave is working all weekend or not :)
Annnnnnnd I am about to put my car up for sale, so really shouldn't be taking it too the track .... should I ?
But all in for helping on the day guys :down:
^^ knowing my luck.. Dave and I will manage to break the unbreakable... lol
Il think about it though... Il more than likely cave and at least enter for one of us to drive it :)
damn it....
Yes, yes you should be taking it to the track.
It's your car until money is exchanged and signatures put on rego transfer! Take it and have some fun... Rip an epic skid, and show Steve how much he can't drive your car... ROFL
no, the pic isn't old, but your epic fails are
I agree, so far I have driven home from all of my track days. My fails aren't epic enough :)
EDIT
and now that I have said that, my car is going to die at this track day :ninja:
Come on kiddies get in for an awesome day!
If all the moons and stars align in my favour i should be there in the Failvia running full slicks for a giggle.... BUT time will tell :D
As for all you others, DO IT!
EDIT
and now that I have said that, my car is going to die at this track day :D
ahahhahaha
I'd love to come to this, but I've got skirmish the day before and i'll probably be too buggered to drive all day... :P
Nah man, you'll be fine the next day.
Skirmish doesn't tire you (Well me anyway) as much as people say
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
