is the car modified?
we have done one with a Plazmaman plenum which requires the stock throttle body to be changed
which in turn throws the same lights as your car
still trying to figure out a work around for this issue
The TCS/Slip & Engine indicators lights during normal drive, can anyone tell me what causes that and what I need to do to diagnose exactly where went wrong?
thanks heaps
I'm having the exact same issue lol :)
I got my R34 GT-T not even a couple of weeks ago and this happened to me for the 3rd time just earlier tonight. Driving along, car seems to go a little funny for a moment, but keeps traveling along just fine. TCS Off, Slip and Engine lights come on. Pull over, turn off car for a few secs and restart it and it's fine again.
I checked the ECU Fault Codes (shorted pins on consult connector), engine light flashed Code 21. I've been reading up on this over the past few days and yeah .. Pretty much what JI34GT said. Err 21 pertains to the Ignition circuit and is well renowned for being problematic coilpacks. The general consensus is to replace them. That's what I aim to do over the next few weeks. Do a search and you'll find other threads on the topic.
The only question I have now is why Nissan made it so it lights up the TCS/Slip lights .. Bit misleading isn't it?? :ph34r:
Fingers crossed it'll fix things up, might be good for current/future power gains and possibly also bring up fuel economy a bit if it's been crap.
Edited by Rake
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
