Firstly check VIN # > History of where it was owned. If it came from anywhere on the north island of Hokkaido (ie names like Kushiro, Sapporo, Hakodate, Asahikawa, Muroran etc) the chances of rust are huge.
Where? As mad082 said^^^, and also struts, rails, door hinges, wheel well...
there is one more spot. dont forget to look around the boot brake light, it can get rust around there, mine has a little bit atm.
That is indeed the most common arear for rust. I've seen a lot of new imports with rust just below the brake lens, including my old GTT.
  • 3 months later...
It is very common - but not something to worry about because it's one area where the rust is quite visible; and thus, most people attend to it quickly.
After washing the car, you'll notice that water likes to sit beneath the lens; so it pays to soak it up.
After it's fixed, it won't tend to recur under Australian conditions because in Japan, where there's salt in coastal areas, salting of roads in Hokkaido, SO2 & SO3 gasses (emitted by lots of cars in crowded cities where many drivers don't drive very far) which mixed with moist air > H2SO4 (sulphuric acid).
Cheers Terry, thanks for the fast response and clarification! ;) Any other known potential rust trouble spots that should be checked apart from around the spoiler base and around the windows?
Thanks again mate!
Edited by KR4-GTR
The most common area I see from freshly imported cars into our workshop is the underbody. Mostly it's light surface rust from the salt used in snow regions which can be removed. But on some occassions I see quite substantial rust which obviously is a lot more difficult to remove.
Those salty roads are the pits.
Talking on Nissan 4x4 forum to a guy in Ireland who bought a low mileage 2nd hand Patrol but she's got an engine oil leak.
Turned out the sump has rusted through.
Piece of foam material between bellhousing and sump had absorbed the brine and rusted right through the sump.
Wondering about the rest of the underbody?
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
