  • Replies 43
Posted Images
Has anyone looked into the Falken FK452s for the GT-R? They are 255/35 and 285/30 resulting in overall diameter of 680 and 687 mm. Apparently they won a recent wheels tyre test. They are lower profile than standard though. If theyre cheap and as good as they say they are then they may be a good option.
You could also match up their 305/25 with their 255/30 fronts for an identical diameter of 661mm however I'm not sure this would really help the balance of the car.
Edited by fungoolie
A couple other questions:
Does the lower sidewall height on the lower profile non run flat compensate for the stiffer sidewall on the taller runflat? I'm just curious as to how this will affect the ride/handling. If you were too look at this 30r/35f profile combo instead of the 35r/40f you suddenly jump up from having a choice of about 4 road tyres, Bridgestone, Dunlop, Pirelli, Michelin to about 40 on the tire rack website.
Does anyone know what rolling diameter difference front/rear the GT-R can handle?
Going down this route for a daily driver gives me the ability to buy a 300 to 500 treadwear tyre for prices ranging from US$119 to US$250 compared with US$400 for the Dunlop and Potenza standard runflats.
Also any thoughts on what your insurance company may say if you change to non run flats?
Thats why the base model GTR IE less run flats, leather trim and bose is lighter, but the manual says its only 10kg lighter.
Base model has run flats and leather. Only the bose is missing and they replace it with crummy gear which probably weighs very similar amounts.
My JDM base model 2008 doesnt have run flats or the full leather trim.
What did they replace the standard Bridgestone or Dunlops with when they brought it in? There is no GT-R model without full leather. Where is there non leather in your car?
  • 1 month later...
any issues running these directional tyres backwards on a perfectly dry track?
QR is trashing my front left tyre.
I guess I am lazy and dont wont to swap the tyres on the wheels unless I have to.
Mark, we've run a few r-spec tyres backwards in the dry with no problems, to get a bit of extra wear from them. Also, changing topic a bit, with the michelin slicks, i dont believe they are directional (some slicks are) and the porsche guys tell me you can even flip them on the rim (despite there being an outside and inside, the outside merely has a rim protector on it).
  • 1 month later...
Our Toyo 888 test tyres have arrived for the Willall GTR.....let the testing begin :(
Hey Martin, any update on the R888 test?
I hope you are looking after Trent. He has something special coming for my car I believe....
well after 30-33 5 x hot lap sessions at QR, the Toyos looked to be shagged.
with the COBB stage 2 tune I managed a 57.68 on the sprint today on the toyos. I reckon they are at least as good as the Dunlops
will be going out on the track with 18's next time and either second hand michelin slicks or RE55. have the slicks here so not sure if I will buy the RE55's - they aint cheap!
  • 3 weeks later...
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
