Hey guys,
I need to find an exhaust shop that will do some work for me, its not for the skyline, but for my mighty micra. I'm grabbing a set of extractors for it, but they only fit models with no aircon. You need to 'dent' the number 1 runner to make it fit, or weld a slight kink to do it properly. Need someone that is reasonably priced to mod the 1 runner for me, and if price is right, they might get my cash for the rest of the exhaust system, just needs a 2 inch press bent setup with a small tip, maybe 2 1/2 inch tip.
I tried right price exhuasts in slacks creek but they weren't too keen on modding the headers, good price on exhuast though.
Cheers,
Matt
https://www.sau.com.au/forums/topic/286697-exhaust-shop-in-south-east-brissy/
Mild2Wild done my catback and hi-flow cat. I mainly went to them as they were pretty much accross the road from my tuner and I was getting a turbo conversion done so there wasn't a lot of options for me.
They seem to have done a good job with it all, bit droney though, but nothing that fitting a resonator and something other than a canon tip won't fix. Something I really should get around to doing soon, though.
Plus one for CES in meadowbrook.
Just had a catback made up by them for the r34 gtt
couldnt be happier.
Not the cheapest by any means, but they'll do it right and do it right the first time.
Trevor is a good guy to talk to also. will give you alot of options not just the one that is best for him.
hmmm I might check out performance pipes, they're very close to where I work and I must get around to getting a resonator fitted to quieten the exhaust down. Are they reasonably priced?
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
