Hey guys,
I need to find an exhaust shop that will do some work for me, its not for the skyline, but for my mighty micra. I'm grabbing a set of extractors for it, but they only fit models with no aircon. You need to 'dent' the number 1 runner to make it fit, or weld a slight kink to do it properly. Need someone that is reasonably priced to mod the 1 runner for me, and if price is right, they might get my cash for the rest of the exhaust system, just needs a 2 inch press bent setup with a small tip, maybe 2 1/2 inch tip.
I tried right price exhuasts in slacks creek but they weren't too keen on modding the headers, good price on exhuast though.
Cheers,
Matt
https://www.sau.com.au/forums/topic/286697-exhaust-shop-in-south-east-brissy/
Mild2Wild done my catback and hi-flow cat. I mainly went to them as they were pretty much accross the road from my tuner and I was getting a turbo conversion done so there wasn't a lot of options for me.
They seem to have done a good job with it all, bit droney though, but nothing that fitting a resonator and something other than a canon tip won't fix. Something I really should get around to doing soon, though.
Plus one for CES in meadowbrook.
Just had a catback made up by them for the r34 gtt
couldnt be happier.
Not the cheapest by any means, but they'll do it right and do it right the first time.
Trevor is a good guy to talk to also. will give you alot of options not just the one that is best for him.
hmmm I might check out performance pipes, they're very close to where I work and I must get around to getting a resonator fitted to quieten the exhaust down. Are they reasonably priced?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
