Well I got a little curious about this, and had a few parts off so decided to weigh them on some digital scales. Now you see all these drag or race cars with absolutely everything stripped
off them. When I look at what I have measured, and thought about it, was curious as to exactly how much they were saving.
So here are the things I have weighed so far to try and get imperical about it all. This is for a 33, I assume there will be subtle differences for 32 and 34. If people have weighed these items off their cars, add them to this thread and I'll add a 32 section, etc.
33 GTS-T (series1)
Mirrors: 2kg x 2 = 4kg
Front Door trims: 2.5kg each x 2 = 5kg
Standard "Space Saver" spare: 14kg
Standard boot "floor" (although I have made a custom MDF floor): 2.5kg
Stock Bonnet: 18kg
Front guards - 3kg x 2 = 6kg
Whole dash structure = 7kg
Centre console = 4kg
Glovebox assembly = 2kg
Stereo equipment:
Standard amp: ~2.5kg (of course this can vary a bit)
Pair of speakers: 2kg x 2 (front+back) = 4kg
12" dual coil sub in standard sized box = 13.5kg
Extras you might carry:
Toolbox filled with misc tools: 9.5kg
Person: 70kg+(!!) get rid of them :P
Some estimates based on previous pullings out:
Rear seat: 18kg
Front seat: 18Kg
R32 (series1)
Stock GTS-T bonnet: 20kg
Aircon compressor: 9kg
Rear wiper motor: 2kg
Stock intercooler: 4kg
I assume the majority of savings will come from seat removals (maybe 60kg in those items), light weight wheels (maybe 40kg?), aircon (20kg?), removal of "excessive" bodykit (30kg?) items and maybe c/f bonnet (10kg difference?). So if anybody can put up figures for them, would be great.
So well I hope this thread where people pulling various bits off their cars can put them up in this thread, and we can get a bit of a definitive guide for those looking for weight reduction savings for the drag strip, or anything else.
Unfortunately I have never been on a weigh bridge and been able to measure the weight of my 33, so its difficult to see where I'm actually startng from, but this is a start.
https://www.sau.com.au/forums/topic/28670-weight-reduction/
i think the bonnet(standard-> FRP/carbon) with save u 10kg.
Light weight rims with save u a few kg EACH! from just changing the stock to TE37, u save over 1xkg and handle a lot better!
and those preformance parts, light weight flywheel, forgre piston... anything under the engine bay is reducing weight. it's always the best to reduce weight from the front part.
recently i remove my FMIC and put the stock back, and i found the the car handling was improve. So anyone with is looking for a FMIC may look if there is any aluminum intercooler +pipe then buy cheap heavy cooler and mild steel pipe.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592599
Originally posted by predator
I was trying to keep this to *serious* discussion about the issue and what is actually worth the effort to remove.. so can we please try and keep it that way? thanks.
Wasn't trying to make a joke about it. I actually thought this would back your statement about weight saving & if you read the article they highlight the gains by removal of differencent parts.
Fair enough the story a bit on the light side, but I & may be others dont really understand the true benefits of weight reduction, & most think Horsepower Gain is priority above all else.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592608
first, remove all the stickers. :)
Things to consider:
- the spare tyre
- back seats
- swap the driver and passenger seats with some semi-buckets and/or buckets (e.g bride brix on driver's, bride ergo's on passenger)
- remove unnecessary boom boxes in da hood
- steering wheel, swapped to something lighter. momo, buddy club, etc.
- air conditioner
- swap to light weight materials if you must, i.e. alloy, carbon fibre, aluminium materials.
that's about all i can think of right now.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592674
Yer, i know it does have its more serious points. But plenty of threads have been dedicated to that site. No hard feelings
If a 100kg weight reduction gives you an equivelent 20-30rwkw (i think that was a figure that has been thrown around), seems like a cheaper way to get better performance. If that 20-30rwkw costs you $200+ to get via horsepower, seems a bit silly when you can get rid of (or upgrade some items).
Bonnet reduction seems a little less than I would have thought. Feeling a carbon fibre bonnet and easily being able to lift in my hands, compared to a hefty lift of a normal bonnet. Would thing it would be more than 10kg? Anyhow, that is why i'm asking people if they have stuff off to measure it. Only takes a minute Thats the only way to tell for sure :)
I mean you don't want to get excessive unless you truly are building a drag car, but every bit helps. I know after measuring some things for example, I'd rather keep the door trims than a few other items on that list.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592713
I'm trying to do the numbers & the cost to lose 100kg=*20-30kw gain doesn't add up when compared to common performance upgrades eg: Exhaust, cam gears, ECU, bleed valves...etc A True Carbon bonnets must be worth around $2K+ fake fibreglass ones around $1K.
Things I can think of would be:
1. Titanium Cat back exhausts
2. I generally find Manufacturers add a lot of fancy covers, slicencer & protectors to the exhaust under-carriage. Either replacing the front half of the system or if possible removng these items.
3. Wonder what all your stereo system would way.. speakers, amps, subbies, CD Changer, deck...etc
4. I'm not sure if this is true, that each litre of liquid eg: fuel, water =1kg. If correct, then I would drive around with a minimum of fuel maybe qtr tank = saving of 40-50kg. Empty the water bottle for the window washer saving 3-5 kg.
If keeping the cars looks & driving comfort isn't an issue then I would also add things like:
1. Carpets, door trims & sound deadning
2. All the crappy pieces of plastic under the guards, the under carriage, rear boot...etc
3. Spoilers, side skirts, maybe even replacing the side glass windows with that plastic stuff??
I'd assume with no real knowledge at a 50-75kg weight reduction.
Overall I still think, lighter parts = more $$$cost than simple performance upgrades. :)
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592887
Im amazed you can pick a difference!
I remove the back seats ond parcel shelp when i go to the track, not becasue of weight but so i can mount a camera on the parcel shelf.
The back seats are very light and combined with the parcel shelf i think they would struggle to make a 15kg difference. When i had the driver/passenger seat out for stereo install, they seemed to weigh quite a bit, so some decent lightweight seats could save 20-30kgs.
If i had a R32 GTST track car i think you would be able to get close to 1000kg without driver, going to the extent of removing std fuel cell and rear boot floor and replacing with smaller fuel cell with aluminiu or carbon fibre floor etc, etc.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592901
I'm trying to do the numbers & the cost to lose 100kg=*20-30kw gain doesn't add up when compared to common performance upgrades eg: Exhaust' date=' cam gears, ECU, bleed valves...etc A True Carbon bonnets must be worth around $2K+ fake fibreglass ones around $1K.
QUOTE']
those are dry carbon, my friend bought a Nismo one R34GTR for a$4000 plus. we can't say 1K one is fake as that was FRP with a layer of true carbon fibre on top. The different as not as hard, yellow color and small crack after years (heat of engine) . But weight are pretty much same.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-592973
R33
Stock bonnet 18Kg
UAS Carbon bonnet 10Kg
Stock front seat 18Kg ( My Recaro is quite a bit heavier)
combined rear sear 18Kg
You don't save much over the stock wheels/205's if you have much bigger lightweights
I have Weds sports racing 18x8&9 with 235 40and 265 35 overall saving is about 0.5Kg. About the same for my Modena 2's 17x8.5&9.5 with 245 40 and 265 35
Turbo is quite heavy....you could save a few Kilos there ;)
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-593062
Hi guys, completely removing the HICAS saved 18 kgs on our R32 GTST.
Ohh and I always make the drivers take a peee before they race, every little bit helps.
lol, no doubt they are so nervous they can't help it.
I'm currently building a car for production car racing, I'll try and get some before and after weights
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-594995
I only ever burn 1 song to a CD when im out driving my car. The additional weight of those extra 19 songs is astonishing.
Oh and use the blank CD's from Strathfields too. . . they are made from a thinner plastic.
https://www.sau.com.au/forums/topic/28670-weight-reduction/#findComment-595039
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
