Got a bunch of things taking up space and they need to go :P
All items are located in Sydney. Pickup preferred, but willing to post at buyers expense
Item: Weather shields
Condition:Good
Price:$80
To Fit: R33 skyline (2 door)
Comments: I had all the clips but recently moved so not sure if i can find them now.
Item: HKS Mushroom Pod Filter + Adapter
Condition:Good
Price:$70
To Fit: Anything
Comments: The induction noise was too loud for my liking, so replaced with stock air box. Filter needs a clean
Item: East Bear Style Grille
Condition:Good
Price:$80
To Fit: R33 S2
Comments: Bought off ebay for 120, but i didn't like the way it sit and couldn't be bothered figuring out how to do it properly
Item: Series 2 Sedan Headlights
Condition:Good
Price:$500
To Fit: R33 S2 sedan/coupe
Comments: Came with the car, but have changed them over. Comes with all plugs and wires. Left light is missing a lower tab, but it doesn't affect anything as all the grilles i've used have not used it.
https://www.sau.com.au/forums/topic/286712-garage-cleanup/
Hey buddy quiet intrested in weather shield but curiosity needs to kill the cat first...
Do they fit S1 R33's? if so have u found all necessary bolts n clips for em?
n where in Syd u located at?
-JAi-
https://www.sau.com.au/forums/topic/286712-garage-cleanup/#findComment-4817671
All items are located in Yagoona, in Sydneys West.
Unfortunately i don't have any pics of the grille on the car, i'll try to take some, just been pretty busy lately. You're welcome to come and test fit it if you like.
Pretty sure the weather shields would fit an S1 coupe, haven't had a chance to look for the clips though :)
Cheers
https://www.sau.com.au/forums/topic/286712-garage-cleanup/#findComment-4818062
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
  • 1 month later...
  • 4 years later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
