Item: Jl audio a2150 mono block amp
Website: -
Item Condition: 1 month old bearly used now sitting around
Reason for Selling: no longer using
Price and Payment Conditions: $350 OnO
Extra Info: still works great near new...All A-Series models are realistically rated at 12.5 volts DC supply and include flexible signal processing sections, differential-balanced inputs and solid, aluminum/steel chassis construction.
SPECIFICATIONS
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm
75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm
150W RMS x 1 @ 4 ohm
Rated Power 14.5 V Stereo: 70 W RMS x 2 @ 4 ohm
110 W RMS x 2 @ 2 ohm
Rated Power 14.5 V Bridged : 140 W RMS x 1 @ 8 ohm
220 W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20 Hz - 20 kHz
14.4V: <1% THD, 20 Hz - 20 kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response: 10 Hz – 25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate: ± 22V / µs
Input Range: 200mV – 8V RMS
Dimensions (L x W x H): 9.80 in. x 9.25 in. x 2.50 in.
250 mm x 235 mm x 63.5 mm
Pictures: attached
Contact Details: here or bbytec@hotmail.com
https://www.sau.com.au/forums/topic/286729-jl-audio-a2150-mono-block-amp/
