hi, i am currently getting my engine rebuilt and putting it back into my r32 gtr and need to know if i can put on a set of -7 turbos without changing anything else like ecu, injectors, fpr? the simple reason is i dont have the money to do any further mods at the minute and would like to get rid of the old turbos - the only other mods done to date are ported cast manifolds, cat back exhaust and pod filters
https://www.sau.com.au/forums/topic/286759-ecu-upgrade-required/
Nistune is the best ECU for what you need. Checkout their website.
yeah i've looked at it but was wondering will the car drive ok with the stock ecu if i leave the boost at factory level for now (the restrictor is still in place so 8/9 psi limit) so i can drive it around for a while before changing anything else
if you havent bought the -7 tubos yet, id swap em for the -9's; new design, more efficient and same response with a better top end.
A mate of mine has a racepace built motor with -5's running the stock ecu until he has enough money for an ECU and it was run on the dyno with safe AFR n Knocks etc.
But best tune asap to get your full potential, power fc is great as its plug n play
I agree, the -9 seems to be a more efficient turbo.
The stock ecu is quite capable of running with those turbos, the question is how much boost u want to run, because it will start to get a little lean in the low to midrange with increased boost levels.... a problem which can be helped a bit if u have an adj. fuel pressure reg. to bump up rail pressure a few psi.
