Well i thought i would post up some pics of my recently purchased 92 gtst type m. Bought it on tusesday and have only been able to get under it today. It's been looked after pretty and has alot of history. Im the second owner in australia. Though it does need some work. New caster bushes, couple lights(indicator and reverse), new steering wheel gear knob and gear selector and handbrake boots etc etc. Also needs a bit of paint on the roof and sideskirts but overall its pretty good. I plan to tidy it up at the moment and add intercooler kit and power fc and the associated upgrades down the line. I like the fact that the car is basicly stock, the only mods it has are: Mild steel turbo back exhaust with a catco catalytic converter and xforce rear muffler, turbosmart blow off valve, whiteline strut brace, k&n pod, mu secret 6000k HIDs, 17inch lenso GT-6's with kumho tyres. Cheers
https://www.sau.com.au/forums/topic/286763-my-new-32/
  • 3 weeks later...
  • 2 months later...
Nice.... needs GTR front though
https://www.sau.com.au/forums/topic/286763-my-new-32/#findComment-4983365
  • 5 weeks later...
hmmmmm.....yeh R32....nice!!!!!.......got any pic's of your Stag?
Don't want to be Captain Obvious here but......
P.S. Am I missing something......Is this thread linked to the rest of the site or something!
Edited by Jetwreck
https://www.sau.com.au/forums/topic/286763-my-new-32/#findComment-5033781
i think someone stole some of your cabin space, gonna be hard to put 8 teachests or a king sized bed in that.
+1 how about a full boori sleigh cot + matching change table + mattresses for each. No trailer needed. :(
Wait - I'll start a new thread...should be interesting...
https://www.sau.com.au/forums/topic/286763-my-new-32/#findComment-5036216
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
