been looking around on ebay and so on for a good front mount kit with piping and cooler for my R33 i want one that i do not have to cut any holes to make it fit.
Is there anyone on here who can steer me into the right direction thank u.
https://www.sau.com.au/forums/topic/286787-lf-good-r33-front-mount/
  • Replies 73
Posted Images
jjr stealth.return flow. No holes. Need a bit of the reo trimmed. and the bumper. Other than that its a good fit.
Have a look at JJR (Just Jap Racing) they have there own part of the forsale section, he has a Front mount kit that requires very little modification, it keeps all the stock pipes and you only need to grind your reo bar back a little.
http://www.skylinesaustralia.com/forums/Co...er-t209304.html
thats the link.
Richard
http://www.perfectrun.jp/src/detail.php?pi...result_mode=pmk
ARC turnflow is by far the best for what U want. Their patented core design kicks ass over all the others
If you want good quality, ARC,Blitz Return flow coolers.. i've had them in the past but because i do alot of drifting, i broke them cores and then changed to a JJR return flow cooler... cheapest :) very good as well im doing 233kws with 17.5psi
AVO also make a good R33 cooler that fits the stock piping. My car had one on it when i purchased it, its black so super stealth. I am making 245rwkw and its still going strong. Only trouble is they are pretty pricey compared to other ones......
Hi all,
Many of you may already be aware that we are the sole Australian distributor for Blitz Japan, and we have just received another shipment of their latest 2009 release Return Flow Intercooler Kits for ECR33/ER34 & HCR32
We have the Blitz Intercooler Kit Type CS in stock for the above models, and have them available and on special at only $799.00
For more details, please click the following URL or feel free to call or pm us and we will be only too happy to assist.
http://justjap.com/store/product.php?produ...=430&page=1
Regards,
Steve
Whats the diff from the CS to the LM? Is it just that the CS is shiny?
The LM Series has been replaced by he CS series.
CS is Chemical Shine, and is a coating used to prevent alloy corrosion.
I have looked at these new CS kits and they look like a great bit of gear, especially at the price Just Jap as offering.
Its a hell of a price thats for sure! Especially seeing how much i paid for my Blitz LM... :P
Still, not overly keen on shiny front mounts. But i bet it looks good. Havnt been able to find any photos yet!
yer same i like the idea of this front mount and price aslong as i can have the front mount in clear view and hide all piping im happy i think it looks best with pipes coming out ether side then both pipes out 1 side.
BUT..if i want a cooler that requires no mods to my car to fit then thats what i will have to settle with.
ANY 1 with pics at all...?
Here ya go:
And nah, you cant see the pipe underneath. Top notch!
Only reason you can see the return on the last pic, is because i messed up a cut :P But meh. Whatever! Paint it black one day!
Edited by gotRICE?
That actully looks better then i thought it would thanks for those pics what type of power do these handle?
I couldnt answer that to be honest, but a mate was using one running 280rwkw and it wasnt hindering anything. If chinese cores are capable of hadling 300+rwkw. Id say the Blitz should be able to handle alot more, but im sure someone can answer that better.
Any FMIC can look good. Its all about the fitment. I messed mine up slightly and it bugs me every day.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
