Lf Good R33 Front Mount
HYBRID VL
 Share
I've got a JJR stealth cooler. Fitment was really not very good, but easily overcome with a bit of know-how.
My only problem is that the lower return pipe sits quite low to the ground and cops the odd scrape now and then.
If you can afford/find a Blitz one, BUY IT.
  • Replies 73
Posted Images
jjr stealth coolers are good a little bit of mucking around to make them fit and make sure your pipes dont blow off under high boost but worth the work for the price and also if you end up wrecking the bottom pipe prety cheap to order the piping kit from Just jap, all the reuturn flows tend to sit low the bottom pipe
Hi all,
Many of you may already be aware that we are the sole Australian distributor for Blitz Japan, and we have just received another shipment of their latest 2009 release Return Flow Intercooler Kits for ECR33/ER34 & HCR32
We have the Blitz Intercooler Kit Type CS in stock for the above models, and have them available and on special at only $799.00
For more details, please click the following URL or feel free to call or pm us and we will be only too happy to assist.
http://justjap.com/store/product.php?produ...=430&page=1
Regards,
Steve
that is an awesome product at an awesome price!!
I used to have a BLITZ LM and it was a fantastic cooler paid $1400 @ Autobarn back in the day
You would be crazy to go past one of these if your going to keep the car fairly stock
$1400! Woooah. I got mine for $1000ishNZD delivered from Nengun last year.
Id settle for the "shiny" Blitz if it was around then for this price!
take acouple of front shots so we can all see
Whilst I'd originally read that the Avo would fit without cutting the reo, their response indicated no. I'd also heard rumours / forum posts of the same with regards to the Blitz and Trust options ... but then other people say no..
I'm honestly getting the impression there isn't a single front-mount intercooler on the market (obviously there's always the custom approach) that will fit back to factory pipes and not require reo cutting. Given the insurance / defect issues with cutting the reo, I'm both stunned and frustrated by the situation. Is it such a big thing to ask for? :D
Damn you bastards to hell. I was all set to go for a Cooling Pro Stealth, after seeing the positive response everyone had for it, and now I'm in two minds about that and the Blitz cooler. Someone make a decision for me.
BLITZ! Its a no brainer.
Seriously, it will be so much more worth it in the long run :thanks:
Ok well when i said about getting a good cooler that requires no holes cut yer i rather cut a hole then the reo thats for sure so now im probley gunna be stuck in a sitituation where if u want a front mount u cut the reo unless u want a ugly looking front mount.
hmmmm so where to go now if im going to have to cut reo i might aswell get a front mount that has pipes both sides.
So.. what your saying is that you DONT want to cut anything, but if you have to, you will cut two things?
Sounds like a cop out to me :(
Pretty much every decent sized FMIC need the reo trimmed slightly. Its just the way they are.
i was looking at the pwr one when i originally bought my car. about 1k for the cooler by its self, only reason i didnt buy it was because i couldnt get a proper idea of fitment (nobody knew how they would fit and modifications required to do so). shame about having to trim the reo, looks like ill be keeping my smic until i find something that doesnt require insurance voids/engi certs.
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
