I've got a JJR stealth cooler. Fitment was really not very good, but easily overcome with a bit of know-how.
My only problem is that the lower return pipe sits quite low to the ground and cops the odd scrape now and then.
If you can afford/find a Blitz one, BUY IT.
  • Replies 73
Posted Images
jjr stealth coolers are good a little bit of mucking around to make them fit and make sure your pipes dont blow off under high boost but worth the work for the price and also if you end up wrecking the bottom pipe prety cheap to order the piping kit from Just jap, all the reuturn flows tend to sit low the bottom pipe
Hi all,
Many of you may already be aware that we are the sole Australian distributor for Blitz Japan, and we have just received another shipment of their latest 2009 release Return Flow Intercooler Kits for ECR33/ER34 & HCR32
We have the Blitz Intercooler Kit Type CS in stock for the above models, and have them available and on special at only $799.00
For more details, please click the following URL or feel free to call or pm us and we will be only too happy to assist.
http://justjap.com/store/product.php?produ...=430&page=1
Regards,
Steve
that is an awesome product at an awesome price!!
I used to have a BLITZ LM and it was a fantastic cooler paid $1400 @ Autobarn back in the day
You would be crazy to go past one of these if your going to keep the car fairly stock
$1400! Woooah. I got mine for $1000ishNZD delivered from Nengun last year.
Id settle for the "shiny" Blitz if it was around then for this price!
take acouple of front shots so we can all see
Whilst I'd originally read that the Avo would fit without cutting the reo, their response indicated no. I'd also heard rumours / forum posts of the same with regards to the Blitz and Trust options ... but then other people say no..
I'm honestly getting the impression there isn't a single front-mount intercooler on the market (obviously there's always the custom approach) that will fit back to factory pipes and not require reo cutting. Given the insurance / defect issues with cutting the reo, I'm both stunned and frustrated by the situation. Is it such a big thing to ask for? :D
Damn you bastards to hell. I was all set to go for a Cooling Pro Stealth, after seeing the positive response everyone had for it, and now I'm in two minds about that and the Blitz cooler. Someone make a decision for me.
BLITZ! Its a no brainer.
Seriously, it will be so much more worth it in the long run :thanks:
Ok well when i said about getting a good cooler that requires no holes cut yer i rather cut a hole then the reo thats for sure so now im probley gunna be stuck in a sitituation where if u want a front mount u cut the reo unless u want a ugly looking front mount.
hmmmm so where to go now if im going to have to cut reo i might aswell get a front mount that has pipes both sides.
So.. what your saying is that you DONT want to cut anything, but if you have to, you will cut two things?
Sounds like a cop out to me :(
Pretty much every decent sized FMIC need the reo trimmed slightly. Its just the way they are.
i was looking at the pwr one when i originally bought my car. about 1k for the cooler by its self, only reason i didnt buy it was because i couldnt get a proper idea of fitment (nobody knew how they would fit and modifications required to do so). shame about having to trim the reo, looks like ill be keeping my smic until i find something that doesnt require insurance voids/engi certs.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
