Raws car
1992 R32 Gts-t
Auction grade 3.5 car
100,000 on the 25 package
motor was rebuilt with new rings and bearings before fitting 20,000km ago
VG30 op6 Turbo (larger rear housing same as r34 gt-t)
New Arp headstuds
New timing belt
pod filter
Tomei 256 Intake cam
New Tomei 1.2mm metal headgasket
New front mount intercooler
full exhaust turbo to tip
full type M body kit rear pods etc
New extreme heavy duty clutch
New D1 strengthend shifter (same through just more postive feel)
Non Hicas S13 rear craddle
Alloy craddle bushes
coilovers
rear strut brace
New Section rear camber arms
Ikea Formula Traction rods
New Kts tie rod ends
New Ikea Formula tie rods extra lock!
New Kenwood head deck
New Alloy Steering bush
New Nolthane Steering rack bushes
HID Cats Eye headlights
Gtr fuel pump
new clutch master cylinder
New front Brake pads
all new fuilds engine oil, brake fuild, clutch fuild, gearbox oil, diff oil all changed 2,500km ago or less
Alarm , keyless entry
custom tailshaft
custom gearbox mount
rb25gearbox
Pioneer 6inch speakers front and rear
Pioneer amp
Front slotted rotors
solid engine mounts
Jjr engine daMPNER
Front strut brace
Battery mounted in rear
New battery
Greddy stytle plenium
Nismo fuel pressure reg
Turbo smart fuel pressure gauge
Autronic smc computer
Alloy radiator
avs rims 16inch rims
not interested in swaps,not complied with 25.
$12.000ono SA Strathalbyn 0431 540 141
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
