hey guys,
popped the car (r32) up on a hoist today and sussed out the struts (as there rather firm, thus i don't believe there stock, not that i have ever found another skyline with stock suspension to compare it too.. haha)
all i can tell is that there black and have "nismo" plastered on the side of each strut.
there quite firm as well. not solid, but firm enough to get more or less no roll around corners.
anyone have any ideas where they came from?
nb. the springs are black as well.
https://www.sau.com.au/forums/topic/286795-nismo-struts/
thats odd, because when you said they were black i thought yep they are stock ones but then you said it has nismo written on it so now im not sure. i have nismo s-tunes and they are silver and the springs are red.
edit: i forgot to add if they are nismo's then they will be at least damper adjustable. on the rears is a little knob you can turn with number 1 to 4 and the fronts have it on top of the struts.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4812938
i got some pics of them that im uploading to tinypic. (ill post them in about 5min, probably by the time i finish writing this), the top of the struts front and rear are just a threaded bolt with a nut on them. im assuming its just the shocker bolted into the strut top?)
i uploaded a pic of teh car itself, its sitting on 17" rims, yet seems to be VERY high, specially for a skyline (lol).
the struts do look black, GRANTED, they are probably very dirty, - i just shoved my phone under the car and took photos, the flash is pretty extreme so everything looks shiny
so the next question is, is for me to lower it, can i just buy lower springs from ebay listed for an R32? or are the struts different?
and the car has already got some pretty noticeable camber, how much does lowering the car effect this?
EDIT:
took a pic of the strut top. sorry about the large sizes/shit quality.
Edited by haleja
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4812998
do standard R32 springs fit into the nismo struts? or are they a 'special" size?
the car looks raised imo, maybe the struts are longer and they got standard height stiff springs.
i only asked about camber as i know you get camber the lower you go, and the car already has negative camber. as much as i want to lower the car, its not really practice if camber goes through the roof.
big questions are.
1. do stander diameter springs fit in to the struts,
2. how much would camber change if i drop her an inch?
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813106
ya know, after looking at the rear of the car for a while, i recon the camber isnt actually taht huge, its just the fact that it has a standard rear bar on it, is quite high, and the wheels are 17" by 9".
so the angle (even though minimal) shows up quite a bit.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813258
yeah the struts look good, just demolished boots lol. i dunno what springs i wanna put on there. tein s tech seem the way to go, but i dunno if they will be too soft for me. otherwise ill prob get some custom made ones, i cant find a place to buy them other than ebay.
off topic, anyone know any good online parts dealers based in AUS?
Cheers for ya feedback scotty.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813374
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
