Hey everyone.
Just had a quick flick through the wheel guide as I am trying to decide on some wheels for my 33 GTR. At this stage it has come to TE37's. I didnt fancy any of the slightly cheaper Work range and dont really want to fork out for LMGT's. The only problem is that im not sure on sizing or offset. Im only really sure of width, and 9.5 all round is what im aiming for.
Is 18" enough to archieve a nice look? Can I get away with 19" or will it spoil the car?
Ive googled around but cant find many 33's with TE37's that have the specs to match, if anyone has had to work through this dilema before your help would be greatly appreciated.
Oh the line is white with standard GTR bodykit and I was thinking of going with the bronze finish...
Cheers,
Justin
https://www.sau.com.au/forums/topic/286843-volk-te37-question/
Hey everyone.
Cheers,
Justin
Nice choice of rims, Heres some nice pics for you..
+22 through to +15 will sit flush on the guards
Cheers
Johno
^^Yeah same.
Mine are +22, 17" rims, Volk TE37's.
18" wheels are the most I would go.
18" seems to be the best size for the R33 GTR, although they came with 17", cuz it is quite a longish / bigger car, it needs 18" just to top it off.
Thanks for the quick response. Awesome. Well thats what im after with the offset too so thats settled.
Johno is that your 33 in the first picture with the white te's? That is exactly the look im after... Are they 18's or 19'?
The 32 looks good too man with 17's...
Erm.. I thought LMGT4s and TE37 are pretty similiar in price arent they? But I heard they stop making the LMGT4s.
Go on the Rays Engineering website and they have the full list of offset for clearing the brakes and the offsets for different cars. Stick with that and you cant go wrong.
+1. Unless you're doing up the car for show if not stick with 18s. If you're getting 18 TE37, get 18" x 10.5 +22 and they'll look awesome.
My LMGT4s are 18" x 9.5 +15 with 285/35 tyres. Have a look in the garage page if you're interested in photos of the car.
Hey Brandon. Just checked your pics out. Our cars are almost identical except for yours being an N1 edish... nice. Even your old bronze rims looked good!
Im still set with the TE37's and will most likely go with the offset you recommend. Thanks for the help guys. I will keep scouting for pics. I like the white but my old GTS-T had white and it wasnt the most fun to keep clean. Will still keep it in mind but want to see what silver and bronze will look like.
Cheers for the help.
Yea, they're not fun to maintain. I'll have to clean them every week to keep them white. Gonna have to buy new Nismo decals for them too. If you cant be bothered cleaning, bronze is definately the colour to get. The bronze Work I had were perfect for that. You cant even tell if its dirty unless you're right in front of them.
  • 4 months later...
I have just been through the same thing myself. I ended up going for a bronze set of 19 X 9.5 + 12 which is the recommended width and offset from Nismo.
Linky Check that out. Although a 34 the 9.5 + 12 sits pretty much perfect. The 19's also have the "dish"... 18's do not
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
