Hi everyone,
I am after some new cam gears and saw the just jap are a lot cheaper than jap brands. Does anyone know if quality is just as good as the imported brands or if anyone has not so good experiences with them.
Thanks.
I have no experience with the just jap ones.
my favourites at the moment are made by envy imports. for one thing they are actually made in australia (not chinese made ones like some other cheapies). plus they use a STEEL outer gear not aluminium like many other (in fact they actually buy and use the outer gear from standard cam gears) and they have machined up their own alloy centre plate and use a 5 bolt retaining system. perhaps give them a try. they will be good in that their wear resistance is OEM standard. apart from them I use and like the trust ones and the tomei ones. both good designs.
http://www.envyimports.com.au/
Cam gear is a cam gear to be honest.
You can get the stock ones made into adjustable if you really are that tight for cash.
Although that said, if you're being this tight over cam gears - you shouldn't have brought a GTR - they get expensive :woot:
You only need to be wary of EARLY series HKS ones (you'll only get them 2nd hand these days), they were a bit poor in metals used and wore down over time.
Thanks Beer Barron, I will get th trust ones as these seem to be a good price ATM.
Thanks nizmoid, I have had my gtr for over 6 years now so I have a fair idea of what they cost to run.
Just asking coz at $199 a pair the jj gears seem very cheap
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
