Obvious:
RB20DET
6 cylinder, 24 valve
2L
RWD
5 speed manual
Exterior:
R33 wheels
NO rear spoiler
Interior:
Autometer Phantom boost gauge
Razo:
turbo timer
gear knob
pedals
JVC cd player
Sony Xplode 6 inch rear speakers
Engine:
R33 (series I) turbo
3" custom turbo back exhaust (including dump pipe, CAT, resonator and muffler - all 3 inch)
TurboXS bleed valve (13psi)
TRUST panel filter in standard box
ARC Side mounted intercooler
Brake booster Brace
Polished Rocker covers
Strut Brace - Front and Rear
GTR fuel pump
All the little things:
100,000km service done at 93,000kms (I have a $1800 receipt for that)
reason for the high cost is a few extra things I did.
*All new polyurethane bushes.. Upper and lower front and rear bushes.
Not cheap at all.
*New 2 core radiator
*Redline gearbox oil
*DOT 4 brake fluid
*new diff oil
*new clutch fluid
*New engine mount
Along with new timing belt, water pump, radiator hoses, other belts, spark plugs, injector clean, fuel filter, oil, oil filter.... the list goes on..
Car is currently at 98,000kms
Interior is pretty damn good.
Exterior is pretty good for original paint except where I was badged and the drivers door has a few chips...
Tyres are 235's on the back and 225's on the front (look a little chunky on the standard R33 rims but they grip really well)
Currently has 153rwkw.
a re-mapped chip should bring it to about 170rwkw and cost you about $200.
I might still do that if it doesn't sell.
All recent pics can be found at http://www.pbase.com/the_r32/inbox
I will NOT separate anything.
I will NOT swap for anything...
$16,500. - NEGOTIABLE
Sydney Only.
https://www.sau.com.au/forums/topic/28689-fs-r32-gtst-silver-16500-sydney/
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
