Hi All
I am selling my R32 GTR - recently rebuilt engine (i picked the car up today with only 250km on the engine - a further 1250km before the rev limit is taken off and the final tune is done).
I am after $25,000. Have receipts for well over $30,000 for repairs and improvements etc - $16,000 of them at Advan by me.
Email me if interested - I am in Sydney. jonathon.a.pearce@au.pwc.com
This car has a host of extras. Recent addition to the family proving to be more difficult to manage than thought. All import compliance docs and receipts available.
Engine firstly rebuilt less than 9000km ago (3000km on it when I bought it) - bad ring assembly and running rich meant I have had to rebuild the engine after owning the car for less than 6000km.
New engine less than 300km - built by Peter Hopkins of Advan Performance. Motor comes with warranty. I am currently running the engine in - just got it back today 9 Sep 09.
Engine
OS Giken Forged Pistons - brand new
ACL Race Bearings- brand new
ARP con rod bolts- brand new
N1 Oil Pump- brand new
Metal head gasket 1.2mm- brand new
New Clutch
Reco Flywheel
Sard 700cc injectors and hi flow fuel rail - less than 2000km
Adj cam gears - less than 2000km
Re-located oil filter - less than 9000km
Splitfire coil pack - less than 9000km
NGK Iridium Plugs - New
Head serviced etc - New
Turbos - Hi Flowed steeel bearing N1 spec - less than 9000km
Apexi pod filter - less than 9000km
Exhaust 4 inch through to HKW Super Dragger muffler - less than 9000km
Link G4 EMS (AFMs no longer needed) - less than 2000km
Turbosmart E-Boost 2 - less than 9000km
HKS Turbo Timer - less than 9000km
Momo wheel
Tinted windows
Pearl Maroon/red paint
Rays 18*10 rims + 98% rubber
Alarm, central locking and anti theft stuff
Interior A1 condition
New Ventilated discs plus race pads
Gearbox and diffs all A1
Some small scratched on front lip and wheels (from my work car pack) - Otherwise paint is excellent
this car is mint! i have seen it driving around! im looking to buy one again! but not right now! so if its for sale when im ready to buy mate, i will be in contact!!!
i miss my gtr which was stolen! think the wound has healed and its time to replace!
best of luck with your sale mate, if someone falls in love with it, the cash will find its way!
bump for immaculate car!
G
The AFMs are still connected to the Apexi pods but are not used by the Link G4. You dont need them. I just have not got around to getting new plumbing.
I will refund your flight from Melbourne to Sydney if you pay over $20,500.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
